Reply 640 of 1970, by IIGS_User
- Oldbie
wrote:[The logic on whether to use Cocoa or Carbon is made on computer architecture; PowerPC machines use Carbon. I'm not sure if that is actually correct, so if anyone can enlighten me on this matter, please do. It works correctly on my own G4.
Carbon is a technology to run a game or application on both Mac OS 9 and Mac OS X systems simultaneously and will be deprecated in near future. Cocoa technology is Mac OS X-only and should work fine with every Mac OS X system, even on PowerPC.
I believe, if you check your Cocoa port with your PowerMac G4, it should run fine, so no Carbon port is required anymore, probably.
Klimawandel.
