Reply 700 of 1972, by Neville
- Oldbie
I have a couple of comments here, another result of me having been using DBGL a lot lately.
First thing I've noticed is that copying VERY big text files in the "Notes" section considerably slows down DBGL when navigating between profiles. Normally this is not an issue, but sometimes I've copied there entire walkthroughs, and it does feel a bit slow, specially in USB media. I understand this is very minor and not exactly proper use, and it's not a problem unless you're very nitpicky, but if it has an easy fix...
The second thing is also related to this. For some reason, if you copy ASCII art into it it shows distorted. Not a very big problem for the art itself, but some walkthroughs also contain ASCII maps or tables, and they also get distorted.
And finally, a question. What is the "Misc" page for? I've tried to figure it out by myself, but failed.
EDIT: And I completely forgot about it, but using 0.71a I noticed that many times the program won't close properly. It leaves JAVAW.EXE open and then there's an error when you try to start it again. The issue is solved if you use the program manager to close manually JAVAW.EXE.
