First post, by aazmi
Hello,
I can open/edit files in Brief (an editor) v3.0 but can't see the cursor. So can't tell where am I at. How to solve this problem?
Thank you,
--aqil
Hello,
Thank you,
--aqil
interresting.
might be a bug in DOSBox. You can do little about about the cursor postion. It either works or doesn't work.
Is this Brief a freeware editor ? (so we can download and test it ?)
Water flows down the stream
Unfortunately Brief is not a freeware. It was written by a company named, Underware. BTW I also tried running Brief on DOSBox 0.63 and had the same problem.
--aqil
heh. A program named "Brief" by a Company named "Underware".
