First post, by david.gralha
hi.. can someone please send me the contents of the folder COMBAT from cd6 im having problems running the game.. and when i tried to copy the cd to hd i couldn't copy this folder.... my e-mail is david.gralha@gmail.com .. tnx in advance..
Reply 1 of 6, by eL_PuSHeR
Are you saying you are having physical reading errors?
Try with unstoppable.
    unstopcp.rar
    62.92 KiB
    125 downloads
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 6, by david.gralha
tnx for the reply.. i'll try it...
yeah, physical problems... running the game during the combats (using cd6) it says some files could not be find, so i tried to make an image using nero and had some read errors.. then i tried to copy to hd the entire cd to mount an image, had no problem with other folders.. but in the folder /combat/ i could only copy a few files, most of them are corrupted or smthing...
Reply 4 of 6, by david.gralha
🙁.. one combat worked.. but having a problem in the next combat (weapon2). Im not sure if its a physical read error in the image im using, in dosbox or in the game itself... the game crashes and display the message
"get_memory: invalid memory block reader in heap 'main heap'
internal memory corrupted (lots of numbers)."
    19.93 KiB
    the print screen
