First post, by xjazz
Hi
I would very much like to fly good old Su-27 Flanker ver 1.5 simulator in WinXP but the sounds are missing.
My PC:
Asus A7V333 mother board
AMD Athlon 1800 (~1.5GHz)
1G 333MHz RAM
GF4 Ti4200 64M VRAM
SB Live! Value
WinXP Home sp2
HOTAS
CH FighterStick
Saitek X35T throttle
Logitec FFB wingman pedas
If I inflight mode hit two-three times the CTRL+S keys (sound on/off toggle), the sounds appear for few sec and fade again.
I tested the win95/98 modes for the su27.exe(mission editor) and FSIM.exe (simulation) files but still no sounds 😢
11M stand alone pack (abandon ware)
LINK REMOVED
HOTAS
I combined with PPjoy/PPjoyjoy virtual-stick driver/mixer my three usb controls (stick, thorttle & pedals) to one 4-axis control, which Flanker can accept.
Any hints to look after?
br
Xjazz
Reply 5 of 5, by xjazz
Yes, there are but no nt4sndpatch.zip patch file from 26.01.1999.
nt4sndpatchReadme.txt
"Patch to get sound in Flanker 1.5 on Windows NT 4.
Extract nt4sndpatch.exe and winmx.dll into
x:\program files\su-27 flanker
Run nt4sndpatch.exe. If all goes well, you
should end up with a new file called
fsim.lbb.new in the directory.
Rename the existing fsim.lbb file to something
like old-fsim.lbb and then rename fsim.lbb.new
to fsim.lbb.
Run flanker as normal.
Jason Shannon "(email removed)
br
Xjazz
