Here's the "cure" I found.
For Nvida cards, no direct experience. I only have to recall what iirc Snover already pointed out, i.e. the "Fixed aspect ratio scaling" trick.
But I have an ATI Radeon X1600, so what I needed is called :
"Scale image - maintain aspect ratio" and it can be found in Control Panel | Graphics settings | Notebook panel properties | Attributes.
It works. Glidos is great with it 😎
This thread on ATi & fixed aspect scaling
http://www.widescreengamingforum.com/forum/vi … 8ce1f521a678c9c
and this page
http://www.widescreengamingforum.com/wiki/ind … Pillarboxing%29
have been useful to me.
It seems not all ATI driver/card combo's will show the same behaviour on this...
Incidentally, I will mention here that I did read this :
DosBox and Widescreen monitor(16:10)
about the aspect=true trick in dosbox, but this simply failed by me.
To have it unstretched I need to use the aspect tweak in Catalyst panel, the dosbox.conf settings didn't succeed.
As the laptop / desktop pc sales ratio increases, and so does the widescreen / (narrowendian?)screen diffusion ratio too, more users are bound to face this aspect distortion issue.
The missing numeric keypad at least in 15" laptops (OK, it can usually be fetched by hitting Fn+F11 or something, but it's a pain) has forced me to remap numpad #0 to look around in Tomb Raider... I've chosen Tab as a replacement and now I must say it's even better than the default was 😉
The widescreen will have players do with black margins, but 1024x768 over 1280:800 is no big deal, besides I just hate playing in windowed mode 🙄
it's disturbing isn't it, especially for those of you who have a distracting wallpaper of your favorite sex star dressed in sunglasses... 😎
