First post, by funknova
Hi,
I just bought this game Mortimer and the Riddles of the Medallion for Win 95 but I can't play it on my XP. Whenever I click on the Mortimer Launcher from the CD to install or start the game, it has an error which says "The procedure entry point SUnMapLS_IP_EBP_12 could not be located in the dynamic link library KERNEL32.dll." I've already run it for compatibility mode for Windows 95 and asked for any available support. Please help!
I've checked through the guidelines but I have no idea what they are and how they can be found so I've attached my DxDiag file.
    DxDiag.txt
    52.05 KiB
    353 downloads
Reply 1 of 3, by DosFreak
You'll need to run the game in VirtualBox/VPC/Vmware in Windows 95/Windows98 if you want to play it.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 3, by funknova
I have tried all the applications you recommended but I have no idea how to create a working virtual machine using the cdrom. I've tried somewhat creating a virtual disk in VPC but it always asks me to reboot and select proper boot media or insert boot media in selected boot device. I'm not sure if I'm supposed to attach the CD to the primary controller or secondary controller. The other programs are not much different.. I don't really get it. 😢
Reply 3 of 3, by DosFreak
A virtual pc is just like a standalone PC. It needs you to install the operation system/drivers and software to function.
