First post, by ILL Robinson
Hello all-
Sorry for the n00b question, but I'm trying to find a way to actually enable the Windows screensaver, in combo with DosBox. Basically we have a few comps running programs for an exhibit, but want the comp to kick in the screensaver if the comp is left idle for a minute or so. Right now, dosbox seems to take priority and Windows won't engage the screensaver. I tried changing the conf and shift the priority down a notch, but that didnt seem to help.
Is it possible to have the screensaver come up? This might be a more general Windows question, but I thought to start here first.
Thanks in advance...
Robs
Reply 1 of 8, by MiniMax
Rank Moderator
Moderator
Hmmm. I have no idea how, if, and when Windows decides that it is time to go into screen-saver mode. I don't think it is CPU-usage, because I run one of those distributed computing clients that will use 100 % of the CPU when it can, and Windows still seem to kick into screen-saver mode (which is fine).
So, I guess it is something with mouse/keyboard activity. I don't understand how DOSBox would affect that and prevent the screensaver from kicking in.
As a last resort, how about installing Win3.1 and run the screensaver inside DOSBox?
_________________
Reply 2 of 8, by ILL Robinson
thanks, Minimax. That's not a bad idea. I'll need to locate Win3.1, but it might work. I'll continue to hunt down why my windows config doesnt kick in the screen saver with DosBox active.
Reply 5 of 8, by gulikoza
Having researched this issue a bit...
It's SDL that will disable screen saver when a program is running (except that it didn't work in my case 😜)...you could probably edit the source and compile a version that will not disable it (search for SC_SCREENSAVE). The other problem is that dosbox *might* crash if screensaver is activated (depends on the output mode selected though)...
http://www.si-gamer.net/gulikoza
Reply 6 of 8, by ILL Robinson
Hi Gulikoza-
Thanks for the heads up - that makes sense. Unfortunately, I'm not much of a coder - not that I wouldn't compile it, I just dont have a compiler to do so.
Until then, I might have to go with running any of the DOS programs in a reg WinXP command prompt.
Reply 7 of 8, by ErikGG
Well thats easy to fix, here is a small app I compiled a few minutes ago. Just unzip and run.
When started, it will set the screensaver to active every second. With active I mean let Windows know it is OK to run a screensaver, not run the screensaver itself.
I added a small button to the app so that you can immediatly run the screensaver.
This should solve the screensaver problem. But remember what gulikoza said, it didn't on my account :
Erik.
    SSActivate.zip
    203.5 KiB
    322 downloads
Read the new FAQ.doc
