Prehistorik 2 / Prince of Persia 2 problems
First post, by CLimaPT
Well, on prehistorik 2, when I reach like level 4, or 5 not sure, like middle of the level, the screen just goes weird and I can't the see guy or anything else.
About Prince of Persia 2, me and my friend have the same sets on both computers, but here it just skips the cutscenes for some reason, while on my friend's it doesn't (for example the flying carpet cutscene when you finish level 4 to go to level 5).
Hope you can help me! Thank you.
Reply 1 of 34, by wd
Rank DOSBox Author
DOSBox Author
What OS? What dosbox version?
Reply 2 of 34, by CLimaPT
Windows XP Pro SP2
DosBox 0.70 (the most recent one, whatever)
Reply 3 of 34, by wd
Rank DOSBox Author
DOSBox Author
Does the screen corruption of pre2 happen always at the same place?
Is just the palette corrupted? Does loadfix help?
Reply 4 of 34, by CLimaPT
always at the same place, I havent played any further since it messes up so i dont know if it going to mess later in another levels
Reply 5 of 34, by CLimaPT
loadfix?
Reply 6 of 34, by wd
Rank DOSBox Author
DOSBox Author
Just type "loadfix" before starting the game (pre2 or prince2, maybe try
for both).
Did somebody else play Prehistorik2 that far yet?
Reply 7 of 34, by CLimaPT
nope tried loadfix for both none worked 🙁
Reply 8 of 34, by CLimaPT
pop2 cutscene skip: http://www.sendspace.com/file/slliuc
pre2 wierd screen: http://www.sendspace.com/file/azypj4
pre2 blinking difficult menu: http://www.sendspace.com/file/9ze1ao
I've uploaded these videos, so you can really see what are the problems.
About the messed up screen I told you about, in fact, it isn't in the same very place. I get it sometimes when I get hit by a monster, but if I walk around with the screen like that, for some time (even though I can't see myself and monsters), it manages to go back to normal somehow. You can see this in the 2nd link above, so you'll know what I'm talking about. Sorry for the huge size od the video, I don't really know how to manipulate it.
Reply 9 of 34, by wd
Rank DOSBox Author
DOSBox Author
Looks like a vga wrapping bug, but quite odd that it happens somewhen
during normal gameplay.
That intro scroller "blinking" is known, doubt that will be ever fixed but
it doesn't have any negative effects.
Got to see what prince2 does for me, but you said it happens on your pc
only and on some different pc the cutscenes are fine? Are you using the
exactly same version of the game, and the same dosbox version?
Reply 10 of 34, by CLimaPT
yes 100% sure, I'm using DosBox 0.70 and Prince 1.0 so does my friend, but I'll get 1.1 to see what happens 😀
and yeah it just happens on my comp as i said
I played this ages ago (like in 1996 or something) and I went farther than the level that is buggy and as I remember there were no more bugs such as this one, the messed up screen. Might only be this level.
Reply 11 of 34, by wd
Rank DOSBox Author
DOSBox Author
Hm cutscenes of prince2 are fine for me. Be sure to test it with only
default dosbox.conf settings (besides mounting).
Reply 12 of 34, by CLimaPT
I have the original dosbox config file and mounting instructions at the end of it. I havent changed the file at all. 😖
Reply 13 of 34, by wd
Rank DOSBox Author
DOSBox Author
And the cutscenes never occur? Like not only when you reload the game
but when playing it from the start?
No idea then. You could play with some of the dosbox.conf settings like
using core=dynamic and turning off the sound devices or so.
Reply 14 of 34, by Wintermute
Actually I also had the cut scene problem some time ago. I wasn't able to solve it and since banished the game from my hard drive. (Unfortunately I don't remember the configuration I used.)
When I started a new game, the cut scenes still played, but sometime during gameplay they stopped showing up. I guess this had to somehow with the savegames, since once it stopped working from a specific savegame there was no chance of them reappearing with this save slot.
Reply 15 of 34, by CLimaPT
hmmm Maybe your right. I got a like 2 saved levels and one of them is level 4. ^^
I'll try install the game again with no level saving. If what you say happens I'll report here right way.
Reply 16 of 34, by CLimaPT
I'm sorry I feel kind of pathetic right now, sorry for wasting your time wd.
It seems you were right after all. The version of prince I had, was the first version ever made known as initial realease, I didn't have 1.0 after all. I went to get 1.0 and now the cutscenes are working finally. 😁
Once again, sorry.
What about pre2 messed up screen on that level?
Reply 17 of 34, by VisitntX
For the Pre2 try to change the core to normal, some games have problems with dynamic.
Reply 18 of 34, by CLimaPT
I did that. The messed up screen didnt show up, but I don't know, 🤣. Maybe it was just luck. 😜
Please take a look at the video below. Is that blinking normal?
Reply 19 of 34, by wd
Rank DOSBox Author
DOSBox Author
Well it's not normal, but can't do anything about it at the moment.
They're using some vga register tricks that aren't supported by dosbox,
but it does not affect gameplay so well.
The screen corruption didn't happen for me yet.
