First post, by Aurous
I have recently blown off the dust of my Old Privateer 2 for Windows game and was Cool let's play this again! after trying to install the game on my system it's telling me thairs not enough Drive space on my HD.... I currently have 2 40GB drives in NTFS i thought maybe the NTFS and the drive size was the problem so i cleaned my spare 40 and re partistioned it as a 300MB Fat32 drive it still says thairs not enough room on the drive even though it's only 90 MB for the install??? anyone have this problem and find a way around it???
Thanks Aur
Reply 1 of 2, by DosFreak
If you try to install on Windows XP and have a large hard disk you get the "not enough disk space available" error message. If you manually make a directory of "c:\dark" first on the hard drive the game will install with out any problems. I have tried this on both fat32 and ntfs partitioned drives, works every time. By the way it can be any drive partition that is available not just C:
Thanks for the tip Bart Hunt.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
