First post, by ArturoYee
I have an application that runs in DOSBox on a Mac (OS 10.3.9). The program have to run from the CD. During the initialization, it does recognize that it is running from a CD Rom.
I have a C:\ drive set up for its temp subdirectory - and *.tmp files are written to the temp folder.
The software works up to the point where it has to go back to the CD to get additional information, and I get the error message
ERROR - WRONG DISK IN DRIVE
Is myy conclusion is that the software does not recognize itself as a VOLUME correct?
Attached are two files - one from a PC (software works) and from DOSBox (wrong disk...).
So - is there another way to mount a CD ROM?
I used mount e /volumes/TestCD -t cdrom -ioctl
to mount the CD Rom.
    PC.TXT
    185 Bytes
    120 downloads
    DOSBOX.TXT
    150 Bytes
    120 downloads
Reply 1 of 11, by Kreshna Aryaguna Nurzaman
Wait:
and:
So, you're running DOSBox on a Mac, yet you're using ioctl switch. Frankly, I've never ran DOSBox on Mac before, but isn't ioctl for Win2K/XP only?
How about using -usecd instead of -ioctl? Have you tried it?
Kreshna Aryaguna Nurzaman.
Reply 2 of 11, by ArturoYee
Yes - you are correct. -ioctl is for Windows.
Just found this thread - (known problem?) It sounds like exactly the same problem:
CD-ROM issues in OSX
I will give it a try anyway (cd was left at the office)-
Oh well, I was getting so close to getting this to work!
Reply 3 of 11, by Kreshna Aryaguna Nurzaman
Options […]
Options
-t (type)
specifies the type of the mount. Supported types are dir (default), floppy and cdrom.
-label (drivelabel)
sets the label of the drive. This is needed on some systems if the CD label isn't read correctly. It may be useful when a program can't find its CD-ROM.
-aspi
forces to use the aspi layer. Only valid if mounting a cdrom on Windows systems with an ASPI-Layer.
-ioctl
forces to use ioctl commands. Only valid if mounting a cdrom on Windows systems which support them (Win2000/XP/NT).
-usecd (number)
forces to use SDL cdrom support for drive number. This number can be found by running mount -cd. Valid on all systems.
-u (drive-letter)
unmounts the selected drive.
Well those are the options. Both ioctl and aspi are Windows-related options, so I guess you're left with usecd.
Reply 4 of 11, by Kippesoep
Have you checked that one:
-label (drivelabel)
My site: Ramblings on mostly tech stuff.
Reply 5 of 11, by DosFreak
don't forget imgmount.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 6 of 11, by ArturoYee
Tried -usecd 0 (mount -cd gave me the fake cdrom at 0)
and
-label TestCD
Going to learn the syntax for imgmount and try that next.
(see attached - my cdrom mount batch file)
    MOUNTCDR.TXT
    59 Bytes
    118 downloads
Reply 7 of 11, by Kreshna Aryaguna Nurzaman
and
-label TestCD
So does it work?
Reply 9 of 11, by ArturoYee
Well, it was a bit of a problem in getting a good ISO. Apple disk utility created an image that could not be mounted - Burn 1.71u crashed when it worked on the .exe.
But I did get a good ISO from my XP machine (using CDBurnerXP Pro 3.0). Thats the good news.
Bad news - same problem.
This is using:
imgmount e /TestCD.iso -t iso
Attached is the message I get:
    7.04 KiB
Reply 11 of 11, by ArturoYee
There is more then one file on the cdrom.
I did a dir *.cfg to get the one file, and try to show that the volume label is not presented. There are 62 files on the CD - 464 megabytes of data.
Yes, it is the right disk, the exe did run, and it reads all the supporting files it needs to run. It is after it gets instructions from the user to extract additional information that it "discovers" that it is the wrong drive.
The error message is from the application.
