Reply 40 of 90, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Oops, mistake above. it's machine=vgaonly, not vga_only.
    38.49 KiB
1+1=10
Reply 41 of 90, by 5u3
Srecko wrote:
"Copper" relies on a fancy dac or crtc programming, some effects don't work with vgaonly (after copper bars, there should be stretching of a helicopter screen but it remains static, also "zooming" effect is problematic)
http://www.pouet.net/prod.php?which=2048
Yeah, this one really shows some creative VGA programming. 🤣
I've used it for years to test CRT monitors and VGA cards for demoscene compatibility: 90% of them won't work correctly. Be careful with expensive equipment when running this on real hardware, monitors can go defective if they are not properly designed.
Reply 42 of 90, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
On the helicopter screen they change the horizontal retrace position which somehow makes the PLL in the monitor stretch the image. I doubt DOSBox will implement this.
The Y-zoom is kinda cheap 😉 they toggle the offset register at scan time to repeat the same lines as often as they want.
1+1=10
Reply 44 of 90, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Fix for programs that do smooth horizontal scrolling.
Fixes:
Supaplex
Wish demo (logo part)
Majic show demo (male/female rolling cube part)
Might have an effect on Micro Machines 2
    panning.diff
    6.26 KiB
    63 downloads
1+1=10
Reply 46 of 90, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Zooming fix - these demos and maybe others make use of it:
Majic12 show, Magic Circle, Copper, GBU, Party91
Also contains the extra fix for copper that reveals the missing parts.
Apparently it also fixes display corruption on (my) host that randomly appers when running the Magic Circle demo.
    zooming_a.diff
    6.58 KiB
    55 downloads
1+1=10
Reply 47 of 90, by Srecko
I only tried Copper (long time ago) on a Matrox Millenium I, but guess it's not the card which this demo was developed on. There was some flickering, but effects were mostly there.
But it seems you figured it out... 😀
Reply 54 of 90, by jal
Lemonzest wrote:
the whole experimental VGA patch. that's what i'm asking about.
What wd in his ever cryptic (but adorable) style is saying is that although there's a VGA patch out there (vgademo, iirc), what hal9000 is making is in the CVS, in the 'main' code (and activated by setting machine to 'vgaonly').
JAL
Reply 56 of 90, by Diduz
This "vgaonly" is great. The water in Sleepwalker (Ocean, 1993) is missing under the official 0.72 binary, but it's back there in the latest Hal's CVS! 😁
I'll try to grab some screenshots tonight.
Reply 57 of 90, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Fix for "Beverly Hills Cop" with machine=ega (shaking energy status bar).
    splitscreen_ega.diff
    709 Bytes
    59 downloads
1+1=10
Reply 58 of 90, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Fix for Doobie3 (pixel skip register "preset row scan")
    preset_scan_vga.diff
    704 Bytes
    56 downloads
1+1=10
Reply 59 of 90, by jal
Are there many bugs to fix, or are you closing in on the last ones?
JAL
