First post, by RX9
Many thanks to WD and all the others who solved the Tandy 1000 HX/PDM2 problem. I thought I would now start a new thread on a related subject.
The final DOS/PC compatible version of DeskMate was version 3.05, and can be downloaded here: http://www.pcxt-micro.com/download/deskmate.exe
I have had this version up and running independently on my Win_98SE system for years with no problem, but I noticed that it cannot be launched from within DOSBox. While there is no current reason for me to do so, I also realize that I am not going to get away with using Win_98SE forever, and the day will come when this will be useful. Experimenting has disclosed that all PC-compatibles versions of DeskMate (3.00-3.05) behave the same way: after mounting the drive and executing "DESK," the file ID tag comes up, then the program exits before doing anything. Note that an environment variable is necessary (set dmconfig=<directory>) which is usually set in autoexec.bat, but can also be included in a regular batch file. I also tried it as a -c command, but note that this does not affect the actual launch of the program anyway; it is merely for config location info. There is something else causing the execution failure.
Does anyone have an interest in looking at this? Thanks.😀
