First post, by Zettt
Hi
I wanted to DOSBox to install a Programm called X-Tracker from D-Lusion.
I have my Home Folder mounted as C:
But when i try to run the Installer i get this screen:
The Installer tries to install to C:\XTRACKER
I am sitting on a Mac with OS X.4.9
Any help would be good. Thanks
Zettt
Reply 3 of 13, by IIGS_User
Maybe some kind of problems with damn access privilegies w/the Unix base of MacOS X?
Klimawandel.
Reply 4 of 13, by Zettt
This is possible. But how do i fix it?
I've tried to set permissions by myself. Creating the directory, setting Permission to rwxrwxrwx and it didn't change anything.
Zettt
Reply 5 of 13, by IIGS_User
Don't know. Not that you have to set your access priv's to admin or higher.
Klimawandel.
Reply 8 of 13, by Zettt
No, sorry. But i have some Linux here. Have tested it there. Same problem.
DISK IS WRITE PROTECTED.
I think it has something to do with the installer, right? 😉
Strange thing the installer creates the directory it wants to install to, but then says it can't write to that disk...
Zettt
Reply 9 of 13, by franpa
maybe the installer it self is on a read only disc/disk?
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 10 of 13, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Installers can be tricky beasts 😀
As franpa said, maybe the installer needs to be on writeable medium?
Maybe (if it isn't already) put it on your mounted C:\ and install from there and do NOT mount your CD-Rom (as I said, installers can be tricky and might not know how to handle a read-only drive EVEN though it is not trying to install to that drive).
Maybe mount c with the -freesize option.
I hope this gets you somewhere.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 12 of 13, by IIGS_User
Zettt wrote:
I am running the installer from my Hard Disk 😀
Maybe it is BECAUSE i am running it from there?
It's possible.
Mounting the installer into Drive A:, the diskette drive?
Klimawandel.
Reply 13 of 13, by Zettt
You're a genious! I knew there were some trick 😉
Now i get another error screen. Has it been posted on the board? (By the time writing this i haven't done a search!)
Zettt
