Reply 20 of 24, by v0g0ns
Well, here are more screenshots, for your viewing pleasure ::) I tried with xms=false, and system shock gave an error of not enough extended ram. I tried with loadfix, and it just allocated 64kb. Fortunately, the color palette goes back to normal after a few seconds. Maybe it's a bug in dosbox?
Hey, I would like to know too, if there's a way to change control keys in system shock, and to speed movement up, using the arrow keys is annoying to move around, and my movement is too slow.
thanks
    33.49 KiB
    29.45 KiB
    33.48 KiB
Rise of the Triad forum
Reply 23 of 24, by wd
Rank DOSBox Author
DOSBox Author
I prefer to install games manually. Keep it simple, that is create some empty
directory (say c:\oldstuff) and mount that as harddrive ("mount c c:\oldstuff").
Then the cdrom (something like "mount d k:\ -t cdrom -ioctl -label XYZ") if
K is your cdrom.
