v0.71's image file size detection
Reply 18 of 20, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
How you can have images larger than 500 MB in official DOSBox:
- Create one with BxImage.
The geometry values have to be recalculated:
Cylinders maxes out at 1024 for DOSBox, however heads can be up to 256.
BxImage will suggest a cylinders value above 1024, so divide cylinders by 2 and multiply heads with 2. Cylinders still bigger than 1024? Do it again and again. You'll get up to about 8 gigs with that.
Example:
From BxImage: -size 512,63,16,1422
Recalculated: -size 512,63,32,711
1+1=10
Reply 20 of 20, by DosFreak
I just noticied today that if you do not specify "-size" and use the autodetect feature then you will be unable to create a partition using FDISK.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
