lemmings - 1991 version
Reply 21 of 27, by froggy
does the screen go any bigger on dosbox .63?
It's set to 1024 x 768 in the conf file. My screen resolution is also set to 1024 x 768.
It's OK as is, but just used to lemmings on full screen on old 486 😀
Reply 23 of 27, by froggy
I've used the old version as when I checked on the game, this version was supported.
I downloaded version .71 and attach the screen dump, which I can't even read. Version .63 works OK (and I can read it) and I can live with the screen size if it can't be made any bigger.
Any suggestions on why the screen short looks so bad would be appreciated.
    Doc1.doc
    93 KiB
    195 downloads
    Screen dump of ver 7.1
Reply 24 of 27, by wd
Rank DOSBox Author
DOSBox Author
Well for 0.63 the upper part of the screen has a bad palette,
for 0.70 and later the lower part has. They switch the palette
in the middle of the screen.
But the game is fully playable in 0.70+ despite of this, and you
surely won't get any recommendations for 0.63
Reply 25 of 27, by froggy
I've tried .70 and it won't work, which is why I went looking for the details on the game. I've attached a screen dump of where I found .63 version against lemmings. Maybe these pages need updating?
My husband can't read the screens between levels, so unless I strike problems, we'll stay with .63 for now. It's working and we can both read it. 😀
    doc2.doc
    148 KiB
    190 downloads
    DosBox .63
