Reply 140 of 146, by Akuma
I ran into a problem with one of the patches: Re: Blood 1997 & Gravis Ultrasound
After an hour of troubleshooting I found the issue to be in one of the .PAT files.
Is there anyone who knows why that patch fails to work with Blood (c) 1997 Monolith,
and can we fix it ?
EDIT: Out of memory, just use the basic sample set without applying the PPL
    73.57 KiB
Reply 142 of 146, by Fuggin-Nuggets
Sorry for the bump years later. I can't get gus working in doom or duke nukem 3d. I tried following the thread but nothing works. I gave up and deleted everything. pulling my hair out here after working on this for hours. help?
Reply 143 of 146, by darry
Fuggin-Nuggets wrote on 2022-03-25, 16:44:
Does it work with any game or application ? Does playmidi work ? AFAICR, at least Doom requires DMA to be working to load patches, otherwise will freeze at startup or make no sound, AFAICR .
Reply 144 of 146, by W49n3r
K.A.R.R. wrote on 2017-02-13, 21:30:
i suggest to simply use pre installed drivers like this one […]
like this one
http://www80.zippyshare.com/v/c6N015fi/file.html
this pack contains GUS 4.11 drivers + Pro Patches Light 1.61 + Pro Patches Lite 1.61 corrected anti looping patches (includes 3 ppl 1.61 patches found by Tsyu removing a looping bug)
I literally registered just to thank you.
GUS Emulation on DosBox eluded me for years (well, I definitely could've put more effort into it... but I digress) and your post was what made things finally work for me.
Man, I feel sorry for my 90s self. Never had a Gravis Ultrasound and finally hearing what it sounded like is pure retrogaming joy.
I just tried now (with the ultrasnd folder above) and worked flawlessly. Be sure to use an up to date DosBox as Gravis emulation didn't work well with some old versions bundled together with the game.
Reply 145 of 146, by Daatta
installing the drivers can cause some problems because no real gus is found or an real autoexec.bat is missing. […]
like this one
Registered to the forum to thank you as well. I had problems with my real GUS 486 setup, never got the Ultramidi working. I even though that my GUS (proud first owner since 90's) is broken somehow and just let it be. But after googling to this thread I decided to give it a try. I downloaded your pre installed driver package, extracted it to the compact flash card (replacing current ulrasnd folder), rebooted the 486 and without much hope ran the mididemo.bat. First nothing happened, I hit the space bar couple of times. Without realizing that it takes some time to load the song, I freaked out as the midi started playing! This is the first time I've heard my GUS playing midi's since the 90's.
I'm so glad I kept the GUS, knowing what the current value is. Gravis Ultrasound was so precious to me as a kid, it served me well until being replaced by generic Sound Blaster card. I lost my 486dx4 setup when my parents house was sold. But just couldn't let the GUS go so i saved it, kept in storage for years. Still have regrets about the 486 though, I should have preserved it too... I was able to grab decent 486 setup a while a go, glad to see that Dosbox can support GUS as well.
Reply 146 of 146, by Jinxter
I made a video where i try so simply the Gravis Ultrasound PnP installation. https://www.youtube.com/watch?v=gqjarrhjgTI
I hope you like it, and that it makes sense.
Check out my YouTube channel: Retro Erik https://www.youtube.com/c/RetroErik
My collection: https://retro.hageseter.com
