First post, by smjg
Using DOSBox 0.72, Windows Vista Home Premium, UK 105-key keyboard (Dell RT7D50 USB if that makes a difference).
An improvement of 0.72 over 0.70 is that it actually has a UK layout. But some keys still map incorrectly. I've managed to put most of them right using the keymapper facility; however, there are still problems:
- Some of the keys I reassign show up as "unknown key"; these work once assigned, but it doesn't save these mappings properly, and so I have to map them again when I next run DOSBox.
- I often have to press the ` key twice before it registers. And once it has, it often gets stuck.
- The keymapper won't accept the \ key on my keyboard. If I try pressing it, nothing happens.
Who else has experienced this? Has anybody come up with a solution?
