Reply 11360 of 40006, by clueless1
Just won an auction for a Pentium Overdrive 200MMX for $18.16 shipped. Considering how rare these are on ebay (the only "Buy Now" one I could find up to now was $49), I'm happy.
Reply 11361 of 40006, by Skyscraper
Grats that was a nice deal! 😀
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
Reply 11362 of 40006, by clueless1
Thanks. I forgot I had a $12.88 credit for the DOA graphics card I just got, so my out of pocket was $5.28. 😲
Reply 11363 of 40006, by torindkflt
Just arrived in the mail is another Toshiba plasma screen portable for my collection! 😊
1.18 MiB
Full System
1.12 MiB
Case Logo
1.58 MiB
Product Labels
486DX-33, 4MB RAM, 200MB hard drive. It tries to boot into Windows 98, but only makes it as far as the Command Prompt because every file in the Windows directory has been deleted (Perhaps a half-assed attempt to wipe the hard drive?).
Unfortunately, it has issues. The screen doesn't want to work until after it has warmed up, then once it finally does become readable, it strobes horrendously, almost like the screen is rapidly turning on and off at about 8Hz or so. A fix for it, if possible, is beyond my current abilities unfortunately. But, as rare as the later plasma-screen Toshiba portables are, this'll likely be the only plasma-screen 6400 I ever find, so it'll have to do. 😵
Reply 11364 of 40006, by candle_86
Not really Retro but some of its old
58.96 KiB
To brand my old and new machines
I really wanted to find one of the old FX 5900 Case badges but I can't find them anywhere, maybe if i can find an image of it in good quality ill get one made some day 🤣.
Reply 11365 of 40006, by shiva2004
shiva2004 wrote:
Today came another package. Between other pieces come this ancient beauty, a Tyan Tiger 100 motherboard with dual P-III @ 500Mhz […]
Today came another package. Between other pieces come this ancient beauty, a Tyan Tiger 100 motherboard with dual P-III @ 500Mhz and an Evans & Sutherland Lightning 1200 AGP graphic card:
A close-up of the motherboard:
And the graphic card, this thing is HUGE:
With it come a 256MB very low density ECC memory module, but it doesn't work; right now it has 768MB noECC memory that I have lying around (the four modules you can see int the photo) and works like a charm.
It's checked up to boot-up; later I'm going to install Windows 2000, and then I'll try some games to see how they run in what was high end hardware in its time 🤣 .
After that, who knows, I love retro computing but I'm not a retro-collector per se, so probably I'll try to sell it.
Well, I finally installed Windows 2K in this thing and it works like a charm. The graphic card only works with OpenGL (absolutely no Directx) but is fast (for its time) and has pretty good VGA quality. Also,a blast form the past 🤣
1.66 MiB
I don't have time or space to use it, so I'm going to sell it after all, but I don't know what is a good price for this items. Can someone give me an idea of how much is worth? (if asking this is against some rule tell me and I'll delete it asap)
Reply 11366 of 40006, by GoblinUpTheRoad
Picked up a few Slot 1 cpus this week. A Celeron 300A plus Pentium 2s in 266, 350 and 400.
122.01 KiB
Now I can upgrade my Pentium 2 machine from a pitiful 350 MHz to a speedy 400 MHz!
Reply 11367 of 40006, by candle_86
why, put the 300A in, set FSB to 100 and smoke that P2 400
Reply 11368 of 40006, by Indrid Cold
Yeah, great overclocker that Celeron 300mhz - I can remember almost all of them reaching 450mhz, but some of them managed the impressive result of 600mhz, also!
Reply 11369 of 40006, by GoblinUpTheRoad
Yeah, I've had a 300A since new back in the 90s, it runs at 450 easily enough, but I'd prefer a P2 400 running stock than pushing 20 year old hardware too hard.
Reply 11370 of 40006, by Indrid Cold
This is acceptable, but I would not be surprised to see live longer these "computing artifacts" of many of those in the present time...
Reply 11371 of 40006, by tikoellner
Today at the local flea market:
Aztec 2320 isa card. Boring, but it was just 2$. Too much, maybe, but want to compare it with my new SB cards (its an OPL3 clone, they say).
Even more boring: Ati 3d Rage II 4mb for 2$.
Nothing more. When I ask about 486 era hw they look at me like I'm nuts 😀. Most probably I am.
Reply 11372 of 40006, by Ozzuneoj
Just snagged this lot for more than I would normally spend on untested old stuff ($52 shipped)... but look at this. 😀
(Seller's pictures)
41.04 KiB
40.68 KiB
42.77 KiB
Parts from an old arcade machine. Looks like a pair of Quantum3D cards, obviously meant for arcade use as they have no VGA pass through. The one on the right actually looks like a Voodoo 3 to me, which I believe were quite uncommon in arcade machines... once I get them I may be able to tell if this is just a normal PC card that happened to get lumped in with arcade parts or if it is actually something special. The board in the back is the main board with the PCI slots on the edges to connect the Voodoo cards. Seller says there is no BIOS. I have absolutely NO experience with arcade machines, so I'll likely only be able to test the video cards. They hardly ever go bad though. I think I peed a little when I found this last night... kind of like the Voodoo 5 5500 PCI the other day... and the Quantum 3D Raven... 🤣
Reply 11373 of 40006, by gdjacobs
tikoellner wrote:
Today at the local flea market: […]
I thought Aztech's OPL3 chip was licensed tech?
Reply 11374 of 40006, by nforce4max
Ozzuneoj wrote:
Just snagged this lot for more than I would normally spend on untested old stuff ($52 shipped)... but look at this. :) […]
(Seller's pictures)
Nice score, just be sure to check for missing SMD caps and resistors especially on that Quantum3d obsidian2. You can with some luck find brackets that will match these cards 😉
Reply 11375 of 40006, by hard1k
Veni, vidi, vici.
Just came to Buenos Aires and got this from the local ads (MercadoLibre):
However I should admit that the assortment of retro hardware that is available here leaves much to be desired when compared even to Russian stock...
New sound card project: AWE64 Legacy
Fortex: Vortex2+YMF744
Reply 11376 of 40006, by Cyrix200+
I got this Pentium 4 system from work a while back. We usually only have dull boxes, but this one was bought as a one-off for something specific (not sure what actually). It's in a nice case (forgot to take a picture) and was clean. Disassembled and stored for a future build!
CPU is a 1.8GHz, 2x 512MB RAM, HDD sounds like a coffee grinder but it boots into Windows XP.
1982 to 2001
Reply 11377 of 40006, by Ozzuneoj
Absolutely. I check cards over pretty thoroughly these days. I've managed to fix any damaged motherboards and cards that I've come across that were worth fixing, so even if there's damage, I can probably fix it with some help... as long as its a common and identifiable component.
I have a whole pile of the little 16v SMD aluminum caps that it seems like every video card from this era used... they bust off extremely easily. I have a 12MB STB Voodoo 2 and a Diamond Riva 128 waiting to have a few soldered back on as well.
Reply 11378 of 40006, by Sutekh94
My latest eBay find arrived today. I'm really looking forward to having a play with this:
Ijc9hYRl.jpg?1
My YouTube | My DeviantArt
Reply 11379 of 40006, by moturimi1
hard1k wrote:
Veni, vidi, vici. […]
Veni, vidi, vici.
Makes me green with envy!
Awesome a Pinnacle with Homac Board. This one is really rare! I do love the Kurzweil synths.
Finally I have a AVM Summit (belonged to Cloudschatze before) and it has definately a different sound than any other soundcard with Kurzweil synth.
AVM Apex and Turtle Beach Pinnacle are far different from AVM summit regarding General Midi. This means the Summit have a different GM ROM content.
