Reply 13120 of 40008, by stamasd
It looks like it's an AMPTRON DX-9200I
http://www.uncreativelabs.de/th99/m/A-B/33142.htm
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 13121 of 40008, by stamasd
Brickpad wrote:
Looks to be the PCChips M915 also known as the Amptron DX9200. I've got the same board, but the ISA slots are white and "Fugu Tech" stickers on the chipset (yeah, right). The lack of an onboard FDD is rather annoying too.
Yeah I was searching TH99 and came to the same conclusion.
However since it doesn't have serial/parallel ports either it looks like one of the ISA slots will go to an IO card anyway. Just have to make sure I find one that won't conflict with the onboard IDE ports. Can you disable or change resources for those in BIOS?
clueless1 wrote:
That's really cool. It would be fun to benchmark the same video card chipset in VLB and PCI on that board.
It would, except that I don't have the same chipset in both PCI and VLB versions. In fact, the only VLB video card I have is a Trident-something, and the only PCI card I have is a Radeon 7000 (which is not even usable in a PC because I flashed it for Mac many years ago and used it in a beige G3 back in the day)
(edit) Not entirely correct. I do have a Geforce 8400GS PCI; for some reason though I suspect I'd have trouble finding this chipset in VLB. 😀
I/O, I/O,
I/O, I/O
Reply 13122 of 40008, by Brickpad
Haven't used the board in a while, so I can't tell you for certain. I'm pretty sure you can disable the onboard IDE controllers though.
Reply 13123 of 40008, by Deksor
Oh a M915i with real cache ? That's interesting, mine have the fake cache, but it seems that I could put some real chips in there because the traces are actually powered. But apparently, the BIOS have been modified to make you believe that you had real cache 😢
But since your board has cache, it could be the unmodified bios (maybe the one that you can found on motherboards.mbarron.net is the same, but I'm not sure ...)
alternative
Reply 13124 of 40008, by luckybob
Mine had cache chips, but they were non functional. Had a soldered bios with fake cache. I really would like to get a proper bios and flast it to this board. It performs EXCELENT.
Reply 13126 of 40008, by stamasd
OK since people are interested in the BIOS, when I get the board I'll make a copy of it and post it.
I/O, I/O,
I/O, I/O
Reply 13127 of 40008, by lolo799
Last purchases, a few pcmcia and ISA goodness:
a pcmcia/cardbus dvd drive, yes, the card has a dipswitch to change between 16bit and 32bit!
54.7 KiB
a 230MB magneto optical drive from Olympus with 10 disks, most of them brand new
43.95 KiB
a Cardbus graphic card for PowerBooks, which is recognized as a Ixmicro 128-3D PCI card under Windows 9x but doesn't do anything...
114.04 KiB
Leadtek Movie Plus 1100 MPEG1/VideoCD playback 16bit ISA card
35.12 KiB
and this 8bit ISA TV Tuner
194.83 KiB
Reply 13128 of 40008, by tikoellner
Today I got totally for free a fine CRT monitor. It's an IBM P260, in a very good shape.
It's truly a monster. 21 inch, more than 30KG of weight. I couldn't fit it in my car's trunk.
P1010116.jpg.
I hope it will be a decent DOS performer.
I must tell you I pretty much like IBM design from this period. Now I'm going to find me some IBM PC 300 series unit to accompany it.
Reply 13129 of 40008, by oeuvre
Bought this for a few bucks. How does it sound? http://i.ebayimg.com/images/g/a~sAAOSwTZ1XmjNi/s-l1600.jpg
Reply 13130 of 40008, by Logistics
I was ready to disregard this as a typical card, and close the window when I barely caught notice of one distinguishable feature of this card, which I don't think I've ever seen on any other card: It uses a dual-mono output stage. The LM386 isn't going to win any awards, but the simple novelty of having an audio-board with dual-mono intrigues me. Interesting find--I want one, now.
Reply 13131 of 40008, by keenmaster486
Well, that is interesting.
[offtopic] someone should make an ISA sound card using vacuum tubes. 🤣 [/offtopic]
I flermmed the plootash just like you asked.
World's foremost 486 enjoyer.
Reply 13132 of 40008, by stamasd
Probably a cost-saving measure. With the side effect that the audio output is probably significantly smaller that with the TEA2025.
I/O, I/O,
I/O, I/O
Reply 13133 of 40008, by BSA Starfire
Found some interesting cards from the car boot sale yesterday, all these were 50p each 😀
First up is this National Instruments PCI-CAN, it seems to be related to automotive ECU's in some way as far as I can figure out. Only bought it because it had that Intel 386 EX 25 MHz CPU on the board! 🤣
1.64 MiB
1.59 MiB
Next up is this Sigma Designs REAL Magic DVD decoder, sadly it didn't have the VGA to S-video cable to connect the VGA card.
1.63 MiB
Next is this ATI Radeon 7000 "GOLD VERSION", anyone know if this is anything interesting? It certainly looks a VERY basic card to have the name GOLD!
1.5 MiB
1.4 MiB
Next post will continue with yesterdays haul.
Reply 13134 of 40008, by Arctic
BSA Starfire wrote:
Found some interesting cards from the car boot sale yesterday, all these were 50p each :) […]
I am in the same boat with the MPEG card and the VGA loop cable problem.
If you find a pinout I could try to make a cable for it 😀
Reply 13135 of 40008, by BSA Starfire
Continuing from above post.
soundblaster LIVE! CT4830.
1.64 MiB
S3 TRIO64V2/DX PCI VGA card.
1.6 MiB
XFX PCI-e Geforce 6200, I think this is the oldest and lowest spec PCI-e video card I have ever come across.
1.34 MiB
1.13 MiB
Reply 13136 of 40008, by jheronimus
Got this Creative DXR2/CT7220 PCI encoder card for free:
109.56 KiB
I thought I could use the VGA passthrough cable from this card for my Voodoo cards, but it turned out to be male-male, not male-female.
Is there anything useful I can do with this card? 😀
Pentium 166 MMX Overdrive, 32 MB RAM, Ark Logic ARK1000VL, Tekram DC-680C, Turtle Beach Tropez, Gravis Ultrasound Max
Pentium III 1000, 256 MB RAM, Matrox G400 MAX, Adaptec 19160, Yamaha YMF740B
Reply 13137 of 40008, by brassicGamer
Re: How to get Realmagic EM8300 Mpeg decoder to work?
Reply 13138 of 40008, by stamasd
Unfortunately it seems that the website linked to in that post is dead, and the Internet Archive is no help. But I have found info about the passthrough cable pinout in this:
http://greyghost.mooo.com/pccbbs/options/magic1.txt
I/O, I/O,
I/O, I/O
Reply 13139 of 40008, by nforce4max
BSA Starfire wrote:
Continuing from above post. […]
Got even older pci-e cards 😉
Before Nvidia had native pci-e support they had to make use of a lot of Geforce FX chips so they made the PCX series as a stop gap until their pci-e Geforce 6 cards were ready. Interesting cards but sadly they got worse specs than the agp models :s
