Reply 14360 of 53009, by sf78
wrote:Alcohol and cotton tip's (Lots of it) 😉
What he means, is that you drink the alcohol and put the q-tips up your nose so that the smell doesn't bother you.
wrote:There is a registry hack that is still floating somewhere on the net that fools the driver into thinking you are using an sli certified board so you can enable sli on just about anything even older amd boards that would have only had crossfire support.
But this card should work in a modern motherboard even if such board doesn't support SLI, right?
Anyway i'm going to do a final test tonight on this motherboard:
The seller offered a partial refund which i'm still considering. I could try to reflow both gpus, but it's still a bad deal even if it works.
Have you tried this / seen it work?
I found tons of threads, but not much luck getting it to work. Nvidia seems to have been very aggressive back in the day to stop this.
wrote:These items arrived recently! […]
I have that exact controller. With a 4.3Gb 7200rpm Seagate Barracuda no more I/O bottlenecks.
Model ST1515 is quiet and should be cheap, however is a servers HD found in many Digital x86 and Alpha servers as RZ29, it has double height compared to modern HD's
Trailing edge computing.
wrote:I have that exact controller. With a 4.3Gb 7200rpm Seagate Barracuda no more I/O bottlenecks.
Nice!
I still have to test the controller. As for drives, I only got a 500 MB and a 9 GB one. The 9 GB has a 80 pin connector, but I've got an adapter for it.
wrote:wrote:There is a registry hack that is still floating somewhere on the net that fools the driver into thinking you are using an sli certified board so you can enable sli on just about anything even older amd boards that would have only had crossfire support.
Used it for close to two years on a AMD board without issues back when I was running two 9800 GT in sli.
OMG!, i got a MegaLITH Plus ISA Memory Card with Driver Disc and Box for Free 😀
I'm really Happy! now i can add whopping 8 Megs of RAM to my 286.
The Card also has Cache Memory wow
wrote:OMG!, i got a MegaLITH Plus ISA Memory Card with Driver Disc and Box for Free 😀
Pictures or it didn't happen ! 🤣
Also has Cache Memory, tried to expand my 286 to 12Mb XMS, but the Card only expands to 10Mb,
Now configured 4Mb XMS and 4Mb EMS but the EMS Driver shows up 4Mb EMS but no Application can find it ?!?
Picked up a nVidia Riva TNT2 M64 32MB AGP card,the 3-notch type that works on everything.
Is it worth anything? Or is it the worst of them (like the GF2 MX200 was).
I recently got a QDI Advance 10F motherboard with a 1GHz Pentium III (Coppermine core) and had no other separate GPU to use it with. (only a 512MB Radeon HD3450 which is just silly on a S370 system - it's currently sitting in a S754 machine)
wrote:Picked up a nVidia Riva TNT2 M64 32MB AGP card,the 3-notch type that works on everything.
For Windows/3D gaming, it's not so hot. Where it would shine is in a late DOS era PC. Very fast and compatible with DOS games, and would be perfect for a P233MX or faster system for playing really demanding DOS games like Descent 2, Duke3D and other Build Engine games, System Shock, etc. in SVGA.
I bought a Roland MPU-401 today that was missing its card, so I also bought all of the parts to build a couple of Lo-Tech MIF-IPC-B cards.
TNT2 M64 is just the second slowest TNT2 variant (only begin faster than TNT2 Vanta), the TNT2 M64 by it's name says, is a full TNT2 with a only 64 bit memory bus unlike the standard TNT2 (with the full 128 bit mem bus).
Acording to Anandtech's review (http://www.anandtech.com/show/393/4). The TNT2 M64 64 bit bus penalizes 32 bit perfomance alot
Perfomance wise
TNT2 M64 loses to:
TNT2, TNT2 Pro and Ultra
Geforce 2 MX (all models)
3Dfx Voodoo 3 (all models)
3Dfx Voodoo 2 SLI
ATI Rage 128 Pro
ATI Radeon VE/700
S3 Savage 2000
Matrox G400/G400 MAX
Matrox G450
TNT2 M64 beats or barely surpasses (afaik):
TNT1
TNT2 Vanta
S3 ViRGE (all models)
S3 Savage 3D
S3 Savage 4
Riva 128
Intel i740
Intel 810/815
i'm not really sure about TNT2 M64 vs:
3Dfx Voodoo Banshee
3Dfx Voodoo 2 (single card)
Intel 845G (Extreme Graphics 1)
Matrox G200
Matrox G220
The TNT2 M64 is a great card for the right games.
If you're looking at Quake 2, Expendable and Unreal, you will likely be disappointed.
But older games should run great on it. It has excellent compatibility with older games, for example Incoming is broken with anything newer than a TNT2. Forsaken, Shadows of the Empire and other older games should all run great.
Bought some mini heatsinks with thermal tape to stick on some gpu memory chips
wrote:Memory chips to upgrade my CL VLB video card to 2MB: […]
is 2MB mem going to make that much of a difference with this card? because i have a CL VLB card aswell.. for the moment
in my 486DX2 80Mhz Asus board
http://www.oldschooldaw.com | vintage PC/MAC MIDI/DAW | Asus mobo archive | Sound Modules | Vintage MIDI Interfaces
AM386DX40 | Asus VL/I-486SV2GX4 (486DX2-80) | GA586VX (p75) + r7000PCI | ABIT Be6 (pII-233) matroxG400 AGP
Depends with Memory Interleave, yes.
If the card does not support it, no.
Just more Colors and Higher Resolutions.
wrote:TNT2 M64 beats or barely surpasses (afaik): TNT1 TNT2 Vanta S3 ViRGE (all models) S3 Savage 3D S3 Savage 4 Riva 128 Intel i740 I […]
TNT1
TNT2 Vanta
S3 Savage 3D
S3 Savage 4
Riva 128
Intel i740
Intel 810/815i'm not really sure about TNT2 M64 vs:
3Dfx Voodoo Banshee
Matrox G200
Matrox G220
The savage 4 whips the TNT2 M64. It's close to the TNT2 (128bit) in performance - it does better in 16bit and worse in 32bit - the savage 4 also does better at higher resolutions in d3d but worse in openGL.
The M64 is faster then banshee / v2 / g200 / extreme graphics 1. The banshee is close in 16 bit single texturing games tough.
wrote:Nope, i don't have any of those, but i believe it should at least work without any problem on the i3 2120. […]
wrote:If you have any nForce 4/5/600 boards try those.
I also have a Celeron G1840 Haswell based system, i should try on that tomorrow.
The 7950 Gx2 is an older SLI video card. The one I had a few years ago worked fine on an intel x58 system, but then again that system's designed to run SLI (or crossfire for that matter). It depends on your system.. you should probably open a thread about it and I can try to help you there better. We're sorta running off topic on this one.. PM me a link if you do start one and I'll try my best to help. Can't promise anything, but it very well may be not compatible with your system, yet actually be an OK card, possibly.
wrote:The TNT2 M64 is a great card for the right games.
Well,this is what I'd want to play on it:
3D:
Beetle Crazy Cup
NFS Porsche 2000
NFS2SE
NFS4
Tank Racer
2D:
Abe's Oddysee
Abe's Exoddus.
