Reply 14460 of 39964, by rkrenicki
wrote:I bought a Roland MPU-401 today that was missing its card, so I also bought all of the parts to build a couple of Lo-Tech MIF-IPC-B cards.
So, the MPU-401 showed up today... it was advertised as "New Old Stock, Missing Box". It showed up in decent physical shape, but obvious signs of use on the connectors and reeking of smoke. I took it all apart and scrubbed the case, and cleaned the board with some contact cleaner. It is much better than it was, but the smell is still kind-of there 🙁 Hopefully it actually works. The Low-tech boards wont be here for a while, so I cannot test it right now.
