Reply 14700 of 52818, by kanecvr
- Oldbie
wrote:wrote:Got a HDT90ZFBK6DGR Phenom II X6 1090T Black Edition today. Not really retro, but a bit rare and collectible nevertheless. Phenom II X6 CPUs to be quite rare in Romania, although there's plenty of them on ebay, but a tad on the expensive side. So far I managed to snag this one for 50$, and an entry level 1055T I got a month ago for 20$. Odd that they're coming up for sale now - I've been looking for one of these for a while now with no luck.
Best part about this 1090T is it does 4GHz pretty easy. I didn't even use a fancy board for the overclock 😀 I wonder if it's even a bit competitive with today's mid-range CPUs.
I think you can outperform the FX 6300 with that OC'd Phenom, AMD Bulldozer based CPUs were known to have worse IPC than Phenom II, especially the Zambezi and Vishera FXs
The 1090T almost certainly outperforms the FX 6300 in games, especially newer ones that make heavy use of multi-core CPUs - the FX 6300 only has 3 floating point units, while the 1090T has 6. Same for the FX 83xx - it only has 4 FPUs. Also like you said, Bulldozer based CPUs were known to have worse IPC than Phenom II. I was thinking more along the lines of competing with a sandy bridge or ivy bridge core i5 (PII x6 @ 4GHz vs i5 stock). I'll run some tests once I get a decent AM3 board.
