Reply 15580 of 52976, by Tetrium
Artex wrote:
Sealed Gainbery MAXimizer GB586-133 http://imagizer.imageshack.us/v2/1024x768q90/924/Ezxbun.jpg http://imagizer.imageshack.us/v2 […]
I wonder if this Maximizer is a Cyrix or an AMD?
Anything in the manual about it?
Just wanted to make sure to add that you don't have to break the seal if you intent to keep it sealed 🤣
My retro rigs (old topic)
Report spammers here!
Reply 15581 of 52976, by ElementalChaos
I've been looking for a period-correct set of speakers for my old PC setup for a while. Finally found these Yamaha YST-M8s at Goodwill today.
I knew Yamaha made good stuff but these things blew me away. I haven't heard better bass response out of any other 2.1 set without a subwoofer.
    4.88 MiB
Pluto, the maxed out Dell Dimension 4100: Pentium III 1400S | 256MB | GeForce4 Ti4200 + Voodoo4 4500 | SB Live! 5.1
Charon, the DOS and early Windows time machine: K6-III+ 600 | 256MB | TNT2 Ultra + Voodoo3 2000 | Audician 32 Plus
Reply 15582 of 52976, by Artex
From what I've read, there are conflicting stories on these. Some say the 133mhz is an AMD chip. Others say it could be a Cyrix chip. The boxes do mention branch prediction which could lean towards Cyrix but I don't know how else to confirm without unsealing it.
Here's the start of a previous discussion on it:
Topic 34088
Reply 15583 of 52976, by brostenen
Artex wrote:
Boxed Synergy ViperMAX (GUS Extreme) Big thanks to a VOGONS member! 😎
Congrats.... That is truely a gem.
Reply 15584 of 52976, by Artex
Thanks! Now the quest for a 'REAL' Gravis Ultrasound Extreme continues...
Reply 15585 of 52976, by brostenen
How rare are this card anyway? I don't recall seeing one elswere than here on Vogons.
Reply 15586 of 52976, by Artex
Pretty rare for this one and the Gravis-branded version (that I recently saw someone picked up here). I've seen bare cards but this is the first boxed Synergy version I've seen.
Reply 15587 of 52976, by Batyra
That was me 😁...
You are looking now for Gravis Extreme and now I'm trying to collect funds for ViperMax.
Everyone is looking for something that someone else has 😀
    335.96 KiB
Reply 15588 of 52976, by dirkmirk
Topic 34088
I purchased a bare GB-133 a few years and unfortunately have to confirm its the amd version, I doubt a cyrix version exists and the box is misleading stating things like "branch prediction & 5th generation"!
edit: Interestingly the "GB-120/100/80" are exactly the same IBM5x86C cpus that run at 120mhz 🤣, geez they did some strange things with stickers back in those days!
Reply 15589 of 52976, by Artex
Topic 34088
Thanks for confirming. I figured as much but still wanted it in my collection as I have a boxed Cyrix Gainbery 120Mhz version as well.
Reply 15591 of 52976, by Kadath
Finally I've bought one of these gems, in excellent conditions, after all:
Toshiba Libretto 50CT
50CT/810 SYSTEM UNIT
MODEL NO. PA1249E
SERIAL NO. X7034401
MADE IN JAPAN
First comes smiles,
then lies.
Last is gunfire.
Reply 15592 of 52976, by kva
Two old via C3 processors for socket 370. One of them is not listed on world-cpu (?) so need to be tested and nicely described.
Celeron Tualatin vs Celeron Conroe at equal clocks
Pentium Pro 256k vs Pentium Pro 1M vs Pentium II Overdrive!
VIA C3 vs VIA C7
My website all about old hardware
Reply 15594 of 52976, by keropi
I received the compact 286/16 machine and so far it looks awesome and small! Here are some pics before I take it apart for the usual cleaning and repairing:
it came with 2 cards installed: an MDA clone and an old NIC:
there is a riser with 3x ISA slots :
the mobo has onboard I/O and FDD/HDD controller - most likely that ACER chip's job:
the PSU is also a good one - I was surprised... all Rubicon caps , a bridge rectifier, decent filtering AFAIK
I genuinely like this machine - small size and packed! I plan to use a CF for HDD (maybe add XT-IDE BIOS somehow on the board's BIOS?) a WDC VGA, a SB2.0 with CMS chips and maybe a MPU 😎
I also received a TYAN quad-opteron setup (no PSU and no HDD though):
case is a Cooler Master CM Stacker in great condition , mobo is a Thunder K8QW with 8GB of RAM along with an EVGA 9800GX2 ... cpus are a mystery atm.
Reply 15595 of 52976, by clueless1
Got these two PCI graphics cards recently. Some quick benchmarks hint that these may be two of the fastest DOS cards I've tested. Will run full tests and make a topic later.
Got lucky on the ARK2000. These are super hard to find, and usually very expensive on ebay. This one had an ambiguous listing description (Gainward VGA Graphics Card), so would've never come up for anyone searching for ARK2000PV. Got it for $10 shipped. 😎 BTW, the "Gainward" comes from the FCC ID, which lists Gainward as the manufacturer.
BTW, does anyone know what type of memory chips go in the ARK2000PV expansion slots? I'd like to eventually upgrade this from 1 to 2 MB. If someone can link to the right part# for me to order, that would be awesome. The existing memory chips look 45ns, so I guess I should get 45ns for the expansion memory too.
1.41 MiB
Reply 15596 of 52976, by kikenovic
Not much going on, a Cirrus Logic GD-5446. I'll use this one with the socket 7 mobo I recently acquired.
    342.64 KiB
Reply 15599 of 52976, by Neco
1.96 MiB
today my Sound Blaster and my Video Adapter arrived.
I also found some other stuff at various thrift shops and a mouse at a pawn shop 😎
1.17 MiB
1.61 MiB
