Reply 1800 of 53039, by Mau1wurf1977
- l33t++
wrote:Finally my card arrived, and not only the disk I connected to it was bootable, but it was visible on dos 6.22. The chip on the card is a Silicon Image 3114, and I'm sure it has it's own bios, that's why it's bootable.
Hmm that's the chip on my card!
I can get into the RAID Bios by pressing F4. Here you can build Raid arrays. Here I can also see any SATA device connected, like a DVD drive or HDD. But I couldn't get it to Boot. I admit I didn't play around much longer as I have a working solution using CF cards but will test again.
wrote:Here is the SI 3114 card, 14 dollars shipped worldwide new:
http://www.ebay.com/itm/4-SATA-S-ATA-Port-RAI … =item2556a904ec
Do not buy the VIA S-ATA card. I just got it and you can't boot from it. Seems to have issues with the Win98 drivers as well.
Ok thanks. And you have this one? And it boots?
wrote:There is one company that still makes them and their main customer is the government because a lot of government departments still run on old tech.
They also still make 8" floppies, tape backup cartridges, and tape on reels.
That's amazing. I have such good memories of these floppies 😀
