Reply 18340 of 39962, by TheAbandonwareGuy
Bought an EVGA 8800GT. The famous single-slot G80 derived G92 based single-slot furnace. I'm going to see if I can't mount a double height cooler from a dead GTS onto it in hopes of better cooling it as I'm willing to bet these single slot coolers on a G80 derivative was never a good idea in the first place.
https://www.youtube.com/channel/UCuFY6ZVlYOXA12tV8b00x_A
1996|P200MMX|64MB EDO|Virge DX 4MB|SB16 OPL3
1999|P3 933|384MB SDR|GF2 Ultra 64MB|CT4620
#Bernie2020 #FeelTheBern
Reply 18341 of 39962, by WildW
That's not fair, now you're on stuff I remember buying the first time around. I bought an 8800GT the moment it came out and had it in my Core2Duo Shuttle. That thing was a pocket rocket =D
Reply 18342 of 39962, by liqmat
Jade Falcon wrote:
Yeah a 1950 seems at place in a early 775 or late 939 setup. But a higher end 775/am2 system is needed to max it out.
Anyway find got a fx-60 and ocz Fatal1ty psu to go with my abit Fatal1ty motherboard.
Yeah, I finally got the small system I am restoring (AMD 5200+, 3GB) up and running with the stock X1950 Pro 512MB AGP card. Getting a 3DMark05 score of 9995 which is pretty good and most definitely faster than the stock NVidia 7800GS and 7900GS AGP cards. So I think I did good on this purchase for sure and didn't pay even close to the higher prices of the used 7x00 AGP cards.
Reply 18343 of 39962, by TheAbandonwareGuy
Yeah 90 percent of the performance of a full blown GTX and half the size and power draw.
Reply 18344 of 39962, by nforce4max
If it is the reference version you can use the cooler from a 8800 GTS 512 but not the G80 version due to the base of the cooler where the vrm and vram make contact though you could possibly mount but you will run into problems with the coils ect being in the way. The single slot coolers could have worked but the design was poor and vapor chambers for graphics cooling was practically nonexistent at the time. I am sure some here still remember the cardboard mods that people did with their 8800 GTX/Ultra where one made a quick cut out then fitted near the end of the card where some of the heat vents out into the case then removed a couple of slot blanks so it would be open. Fun era and for all that was bad about it that era was a lot more fun/work than what people tinker with these days.
Reply 18345 of 39962, by Batyra
Ensoniq Elite w Box and all accesories.
275.23 KiB
BATYRA - Ensoniq Elite Boxed
Reply 18346 of 39962, by kixs
Just went ahead and bought an ATI MACH64 2MB VRAM VLB from another eBay user for more then half the price of today's Swedish auction. It has only standard 2MB but it's enough for me. And yes, it's tested or at least I'm covered by eBay and PayPal.
Now to find ISA VRAM version also tested... there was one on sale last week. But it was untested and price over the top.
PS:
Now I can go back to renovating the "new" house. OK... one room at a time 😁
Reply 18347 of 39962, by xplus93
Just got this today (the blue one). I already have one, but the price was too good. Is there really any difference between the two? The new one is certainly heavier.
    2.19 MiB
XPS 466V|486-DX2|64MB|#9 GXE 1MB|SB32 PnP
Presario 4814|PMMX-233|128MB|Trio64
XPS R450|PII-450|384MB|TNT2 Pro| TB Montego
XPS B1000r|PIII-1GHz|512MB|GF2 PRO 64MB|SB Live!
XPS Gen2|P4 EE 3.4|2GB|GF 6800 GT OC|Audigy 2
Reply 18348 of 39962, by TheAbandonwareGuy
The second one is the OC model with an objectively superior cooler.
Reply 18351 of 39962, by Deksor
@martin939
I remember forgiving to plug the power connector on an Nvidia 8800GT. The PC didn't POST and there was an odd sound that didn't sounded like a PC-Speaker beep. I'm pretty sure it was just a speaker on that card that made that noise
alternative
Reply 18353 of 39962, by liqmat
In the home stretch of restoring and upgrading a Gateway 450. To those who benchmark a bit let me ask you if these are normal numbers.
System now is:
440BX Mobo AGP 2x 100 FSB
P-III 850/256/100
512MB RAM
FX5900 128MB
Corsair 450W SFX PSU
Windows 98SE
3DMark2001 default settings = 6200
GPU Temps max out at 66C during benchmark
Does that sound about right with this config? I know that's a low score for the 5900, but I am thinking the system is holding it back with the low FSB, AGP 2x, etc.
Reply 18354 of 39962, by xplus93
They're bot the OC model. I think i'm going to use the new one with the better cooler. Hopefully that means it'll last longer.
Reply 18355 of 39962, by dexvx
Bought this Asus P5A from eBay. Was lucky and get rev 1.04 (seller had crap photos and messages disabled). Have not powered it on yet. I thought I saw something weird with the VIO (3.5V is lowest it can go but the K6 it came with says 3.3V?).
Also picked up these freebie, Mushkin DDR1 PC3500. Not tested yet. I'm so behind.
Reply 18356 of 39962, by xplus93
Found a new goodwill store and i've fallen in love. Spent $22 and got:
AT keyboard/ Serial mouse KVM (I'm guessing I could use the serial ports instead if doing 9-pin video)
X-Fi I/O drive
BFG 6800 OC
2x TASCAM DBX noise reduction units (ebay!!!)
Reply 18358 of 39962, by cj_reha
Some niced boxed hardware in the clearance aisle of a local computer shop. PCI 10/100 NIC, PCMCIA 56k/10/100 card and 3.5" floppy/CD cleaner.
Also, I set up a deal to purchase any pre-2000 hardware they may get for recycling. Hopefully this will yield good things 😀
Reply 18359 of 39962, by xplus93
That NIC in the foreground was my first. Oh, the memories.
