Reply 21040 of 52813, by easy_john
Predator99 wrote:
All Caps are missing on the soundcard.
When in a childhood you was hit by capacitor, then you grew up and began to take revenge! :lol:
Pentium2 450/256mb/4gb/ati rage 128+voodoo2/SB awe32 8mb+db50xg/GUS PnP 8mb/TB Tropez 2mb
486 DX2-66/32mb/8gb/tseng4000 2mb/SB 16+WB/GUS 1mb/LAPC-I
286 12mhz/4mb/512mb/Vga 1mb/SB 2.0+Covox
PegasosII G4 / Amiga 4000 / Amiga1200 / Amiga 600
Reply 21041 of 52813, by martin939
The Capripper has struck again 😲 If you have a decent soldering iron you could just give it a go, replace the caps and it might still work. Sometimes people think they can make something better by replacing caps/resistors etc, start to furiously remove parts just to realize they don't have the hardware or experience to finish the job and the PCB goes straight to the bin (speaking from my own experience here).
New caps are dirt cheap anyway. Even it turns out to be broken, you've still "earned some exp" for future repairs 🤣
Reply 21042 of 52813, by Predator99
easy_john wrote:
When in a childhood you was hit by capacitor, then you grew up and began to take revenge! 🤣
Hehe, indeed... 😈
No will not give up so fast. Yes, the replacement parts will cost few cent and I will try to repair...
For the caps..
I see here a "10" on the top:
http://imageshack.us/download/845/krk0.jpg
..and here at the bottom..
http://www.amoretro.de/wp-content/uploads/201 … er1.0_front.jpg
a "16".
16V 10µF I assume...
Then I need the thing with the 3 legs...ahhhh...forget the name 🤣 Will desolder the other one and take a look at it...
Reply 21045 of 52813, by feipoa
Vegge wrote:
luckybob wrote:
@Vegge
A 133mhz socket 4 overdrive? Those are NOT common, and generally expensive. I'm envious!
Correct, glad to hear that. 😁 Always interested in uncommon/odd stuff 😀
It looks brand new. Does it work? Curious spacing of the SIMM slots. It has external PS/2 mouse and keyboard ports - is this from a Compaq, Dell, Gateway, or similar case?
Reply 21047 of 52813, by Ozzuneoj
feipoa wrote:
Vegge wrote:
luckybob wrote:
@Vegge
The yellow label on the board reminds me of ones I've seen on Compaq-branded Matrox cards from the late 90s, so I would lean toward it being a Compaq board.
Reply 21048 of 52813, by luckybob
I know it is an Intel board. The L2 cache arrangement is a dead giveaway. Iirc it is the "batman" board. I have no clue why it is called that.
High treason made an awesome video about it: https://www.youtube.com/watch?v=JHVAjUEQi4w
Reply 21049 of 52813, by derSammler
Intel used exactly the same layout for many boards from that era. My Neptune board looks exactly the same, but has socket 5:
file.php?id=40065
Reply 21050 of 52813, by Kreshna Aryaguna Nurzaman
There was a Compaq-branded Matrox card in the late 90's? I frankly never heard of it. What was it? Mystique?
Kreshna Aryaguna Nurzaman.
Reply 21051 of 52813, by Vegge
It looks very nice, but I don't know if its used. Can't give an answer to where it's from either. But yes it works, I had to mod the RTC to cr2032. Sadly it seems to be a bit locked in bios, the advanced chipset menu is nowhere to be found (Ami bios). 😢
Reply 21052 of 52813, by Ozzuneoj
There are a few. I have some. They come up in Google searches pretty easily and some have those yellow/orange stickers.
https://www.google.com/search?q=compaq+matrox … biw=360&bih=530
Reply 21053 of 52813, by jamesp15
I have one from 1997(date on the board) in my collection, its a Mystique 220. I think I have seen a Millenium/Millenium2 as well somewhere.
Click picture for larger.
Reply 21054 of 52813, by DaveJustDave
picked up a matrox power VR card today. Do you think it'll play nice with a voodoo 3?
I have no clue what I'm doing! If you want to watch me fumble through all my retro projects, you can watch here: https://www.youtube.com/user/MrDavejustdave
Reply 21055 of 52813, by TheAbandonwareGuy
DaveJustDave wrote:
picked up a matrox power VR card today. Do you think it'll play nice with a voodoo 3? […]
Probably not.
Reply 21057 of 52813, by Smack2k
Ordered a Female DIN5 to male PS2 adapter as I try to get two Tandy 1000s (SL and TL) working from one Tandy keyboard via KVM. The KVM has DIN5 connectors for each Tandy on the input cables but the output on the KVM is a PS2 port. Hoping the adapter works as I had no luck with any standard or Model M PS2 keyboards I tested
Reply 21058 of 52813, by Predator99
martin939 wrote:
A transistor 😁
Also - check for short on those.
hmpf have all parts together except this "transistor". Its labeled "79L05", a "Negative Regulator". Think I have to order it, all other cards I have in spare have a 78L05 which is different 😒
4.52 MiB
