Reply 21060 of 52782, by Predator99
wrote:79L05 is not a transistor but a voltage regulator. It takes +12V input from the wavetable connector and outputs -5V.
ps: you need to check U1 and C13 (damaged -> replace)
Thanks!
C13 seems to be OK, only a scratch on the surface. Lokks worser on the photo than it is.
For U1 there seems to be a "second" connector pad with 4 pins which is unsed. It looks the same on the reference photo
http://www.amoretro.de/2011/06/terratec-waves … 24-ver-2-0.html
So I think both is OK.
