Reply 22080 of 52803, by xjas
- l33t
Welp, I've been vaguely planning some upgrades for my PowerMac G4 Cube. I was looking around for a CPU module from a "Sawtooth", "Gigabit Ethernet" or "Digital Audio" G4 tower (Apple never officially named these so we go with what we've got) - these are all very similar machines & the CPUs were on little daughterboards that could be swapped around. I actually put out a want ad on a local site, not expecting much, but that netted me this:
...a mighty Sawtooth G4/400 AGP. Nice, except the CPU in the Cube is 450MHz so what's the point?
Well,
Hot damn! A Powerlogix 1.7GHz dual upgrade board. NOW we're talking.
It came stripped of hard drives, but other goodies inside included a 16MB ATI Rage 128 Pro (not a bad card but I've got some better options), a Sonnos Tempo ATA133 card (behind the Rage) giving 2 extra IDE channels, and 2GB PC100/133 SDRAM. Here's a shot of the back of that accelerator board:
(I didn't want to take the heat sink off but yes, there are indeed two G4s on the other side.)
^^ This one even came with a factory Zip250 drive. Apple went on a binge of including zip drives for a while, to appease prospective buyers who were scared of the removal of the 1.44MB floppy. Uncertain times!
(Ironically this would be like Apple of today removing the headphone jack, but then including an 8-in/8-out professional recording interface to make up for it. IF ONLY.)
So yeah, now I'm not sure what I want to do. I was going to use the CPU board in the Cube but maybe I should just restore this one and get it set up instead? It does everything the Cube can do and has PCI(-X) slots. Hmm. Either way, yes, there will be a build thread coming.
