Reply 22480 of 40010, by blurks
I just received a beautiful Siemens Nixdorf PCD-4N in working condition with original bag and power brick. Specs as follows:
- i486SX 25MHz
- 4 MB RAM
- 120 MB HDD
- 512 kB Video
- 640x480 monochrome LC display
- PCMCIA slot
- Slimline floppy drive
Looks preety sleek compared to some of its chunky competitors back in the day... 😉
    217.81 KiB
    296.33 KiB
    204.11 KiB
    202.77 KiB
    243.02 KiB
Reply 22481 of 40010, by jheronimus
Got this SoundBlaster Pro 2 for around 10 bucks with shipping.
Heard a lot of praise about this card, but I am actually not sure what kind of build should this card go into.
Pentium 166 MMX Overdrive, 32 MB RAM, Ark Logic ARK1000VL, Tekram DC-680C, Turtle Beach Tropez, Gravis Ultrasound Max
Pentium III 1000, 256 MB RAM, Matrox G400 MAX, Adaptec 19160, Yamaha YMF740B
Reply 22482 of 40010, by Predator99
😢 Just paid 75€ for this board
265.5 KiB
Micronics 09-00011 with 8 MB of RAM.
Without it this nice board from yesterdays lot...
992 KiB
(Micronics 09-00021) would be completely useless and worthless.
However, the memory card has 72x 511000 RAMs. When I see one of these is sold for more than 1€ the deal was not that bad...
But I dont like to pay that much money for my Retro stuff...
Reply 22483 of 40010, by Anonymous Coward
I am somewhat skeptical that memory expansion card goes with that motherboard. Although they are both Micronics, the motherboard has an extra small connector at the end which will likely prevent the RAM card from being able to seat properly. I suspect the correct expansion card for your board should use SIMM slots according to the components on the board.
Reply 22484 of 40010, by Predator99
Hmm, hope you are not right. But they seem to fit. The 2 small connectors are open at the ends so you can put a card in (through) it. Its not a socket.
And according to
http://webpages.charter.net/dperr/micronics/900010.htm
"The 80386 I-Cache board is a full-sized (13.8" x 12.025") motherboard which took all of its memory as DRAM plugged into a proprietary 32-bit memory card. There are two versions of the I-Cache board, identified by part numbers 09-00010, and 09-00021, which are silk-screened on the component (top) side of the motherboard. The most common memory card used with the I-Cache board is the M500. This is part number 09-00011. The upper left corner has "385 Memory Board" silk-screened on many M500 cards.
Reply 22485 of 40010, by Anonymous Coward
Interesting. So those two small connectors just hold the board in place? I guess if you have documents that list the part numbers they must work together. For the record, I have seen memory expansion cards that appear to use those tiny connectors.
Reply 22486 of 40010, by Predator99
606.59 KiB
Thats what it looks like. When you take a closer look at the gold plate on the RAM board you see 3 scratches on it. So it seems the only sense is to connect all PINs together?
Reply 22488 of 40010, by lolo799
blurks wrote:
I just received a beautiful Siemens Nixdorf PCD-4N in working condition with original bag and power brick. Specs as follows: […]
- i486SX 25MHz
- 4 MB RAM
- 120 MB HDD
- 256 kB Video
- PCMCIA slot
That laptop exists under many brands, like the Dell 433c and the AST 700N:
Re: Bought these (retro) hardware today
Reply 22490 of 40010, by okenido
cyclone3d wrote:
A pack of 100 7"x15" anti-static bags came today. I had ordered 7"x10" bags, but the seller ran out and offered a free upgrade t […]
A pack of 100 7"x15" anti-static bags came today. I had ordered 7"x10" bags, but the seller ran out and offered a free upgrade to the larger bags. Ohhh yeah!
Now I have bags that are the right size for full-length ISA cards.
Just in time for the big lot of ISA sound cards that are supposed to arrive tomorrow.
Can you tell me where you bought them ? I struggle to find them for a good price.
Reply 22491 of 40010, by cyclone3d
eBay:
https://www.ebay.com/itm/100-ESD-Anti-Static- … ls/122190284165
Yamaha YMF7x4 Guide
Epstein didn't kill himself
Reply 22492 of 40010, by The Serpent Rider
Way too much for just unordinary 386DX board.
Reply 22493 of 40010, by cyclone3d
The large lot of ISA sound cards I ordered came in today.
1.57 MiB
Opti, ESS, Crystal, and Diamond Technologies cards.
1.66 MiB
Opti cards, a MAD16 card, a yamaha YMF719E-S and a yamaha YMF718-S card
1.58 MiB
3x, Sound Blaster 2.0 cards, one of which is CMS upgrade-able. The one labeled Sound Machine should also be upgrade-able if the sockets are added.
2x PAS16 cards
Opti card with Opti wavetable card and an unknown non-PnP sound/modem
1.25 MiB
CMI8328 with Crystal wavetable, Adlib clone (PC Symphony)
2x GUS PnP clones (no RAM and no expansion) - what are these good for anyway without RAM
Mystery 8-bit card. Starting a separate thread for this as I am unable to find anything about this card other than the company that made it was Viacon
Last card is the sound/modem card in the previous picture.
Yamaha YMF7x4 Guide
Reply 22494 of 40010, by okenido
Nice ! Are you doing a collection ?
347.52 KiB
OMG this is jumper hell !... Thankfully we don't have to deal with them in most stuff that came few years after.
Reply 22495 of 40010, by Skyscraper
When I was searching through my storage units in search of a certain motherboard I found a box full of "gold scrap" I bought a few years ago. It's CPUs and memory. I know I paid 1 euro each for the CPUs and well less for the memory. There was nothing in the lot I really needed so I diddn't bother to unpack the stuff and just put the it all in storage. I probably have more such boxes I have forgot about.
This evening I will finally sort through this lot.
1.16 MiB
These are the CPUs, they seem to be in need of cleaning. There is also plenty of bent pins.
1.66 MiB
Main PC: Dual Xeon X5690@4.6ghz, Evga - SR-2, 48gb memory, Intel X25-M g2 SSD and a Nvidia GTX 980 ti.
Retro PC #3: K6-2 450@500mhz, PC-Chips m577, 256mb sdram, AWE64 and a Voodoo Banshee.
Reply 22496 of 40010, by cyclone3d
I guess you could call it a collection. I am planning on starting up a web page and doing reviews of retro hardware.
This lot was bought without any idea other than 5-6 8-bit cards and the rest 16-bit.
I really should do a count to see how many different models of sound cards I have now. I have a few plastic bins full now and I need to get a couple more bins as I am out of space.
The jumpers are great on that card. There are even jumpers to disable the modem and sound portions of the card. I may have to take the sticker off the sound chip to see exactly what it is.
Yamaha YMF7x4 Guide
Reply 22497 of 40010, by The Serpent Rider
Hours of pins straightening intensifies.
Reply 22498 of 40010, by okenido
People selling cpus for gold scrap may not know about the retro trends ! They could take care of them not to bend any pins and sell them individually, they'd work 2 times less and earn 2 times more...
Reply 22499 of 40010, by dionb
cyclone3d wrote:
The large lot of ISA sound cards I ordered came in today. [...] […]
2x PAS16 cards
That "unknown" thing could be rather interesting. It's a Prometheus Combo 121, whatever that is. No info I can find anywhere - but Prometheus Products pops up all over the place regarding the "ultra rare" Aria 16. If some of those chips under the stickers are by Sierra, you might have quite a find. Of course Prometheus was also very close with IBM in the mid 1990s, so it might just be an MWave...
