Reply 22960 of 40008, by PCBONEZ
wrote:Back in the day, I had a thing that was supposed to help overclocking socket 7 CPUs. Basically, you slid it on the CPU pins before putting the CPU in the socket. All it was was a thin plate with a bunch of extra smd capacitors on it. Guessing it was supposed to help make the power going to the CPU cleaner. Not sure if it actually helped or not.
If it had power to it the it was probably a peltier cooler.
I remember those being sold for that back then. (With a lot of hype.)
