Reply 23580 of 52822, by Batyra
OldCat wrote:
Batyra wrote:
Just received this beuty… quite not standard colour as for s370...
Oh Casper, the friendly ghost... Is that for a white build?
Exactly! Now I have to find SIS Xabre or Geforce from Triplex… or any other white PCB graphics if there were any other...
Reply 23581 of 52822, by ynari
Nice LP2065! That's my primary monitor too, which I bought second hand.
My recent 'retro' purchase from 2007, is a Zalman Trimon M220W 22" passive 3D monitor. I didn't actually want the monitor, as I already have the Trimon 19" version, but I've lost the glasses, and buying new ones is expensive and requires shipping from the US or Japan.
I then found a UK seller with a 'broken' M220W, complete with glasses, and box. Haggled down to 25 quid delivered, using the Argos collection option. Impressively they'd retained the original box, and it looked in perfect condition. Even more fortunately, the monitor seemed to work just fine.
Unfortunately at this point I finally understood a disadvantage of a passive 3D monitor - for one that large, I simply can't find a position where the whole image is legibly in 3D perhaps unless it's my primary monitor, and this is very definitely a glossy gaming monitor not exactly ideal for productivity. Looking at it sideways on there's always a bit of the display that doesn't look 3D. Being a 16:10 1680x1050 monitor, it's quite wide horizontally. The 4:3 1280x1024 monitor doesn't suffer in this way.
So, let's play 'swap the VESA mount'. The 19" monitor has the shittiest mount ever (tilt only), but the 22" mount is height, tilt, and swivel. 22" mount goes on 19" monitor, an old 17" monitor with a decent mount goes on the 22" monitor, and the 19" monitor mount goes on the 17" - but with the panel rotated, so it's permanently portrait. Win.
Reply 23582 of 52822, by ynari
I've also bought some cheap speaker mounts that I'm hoping will work with my Z5500 speakers - they seem to go through the hole left after you remove the mounting bracket so we'll see (try not to remove the mounting bracket, you can't get it back on without glue)
Reply 23583 of 52822, by wiretap
Starting my collection, here's the stuff that came over the past week.
Compaq Presario 9232 / 120MHz Pentium / 40MB EDO RAM / 1.2GB Quantum Fireball / Linksys LNE100TX 10/100 NIC / 4x CD-ROM / 1.44MB Floppy
Shuttle SK41G / Athlon XP 3000+ / 1GB Corsair Platinum DDR400 / 60GB WD / Floppy/DVD
Refurb Shuttle FX41 Mobo for the SK41G
Creative Dxr2, NEC floppy
Sound Blaster Audigy 2 ZS
Voodoo 5 5500 AGP (2100A)
Abit VT6X4 Motherboard w/ 550 PIII + 256MB SDRAM (Apollo Pro 133A)
ESS Audiodrive 1869F
Sound Blaster Pro 2 CT1600
My Github
Circuit Board Repair Manuals
Reply 23584 of 52822, by JidaiGeki
wiretap wrote:
Starting my collection, here's the stuff that came over the past week. […]
Nice start to the collection! I really like this Presario, haven't seen it before, design is still channeling the older Deskpro design.
Also a nice Shuttle there, see if you can introduce a vent in the case cover near the video card, decent 3D cards can get very hot in that little unit.
Reply 23585 of 52822, by OldCat
That GeForce is Ti4600, so quite powerful for its time... Don't call the build "white power", though! 🤣
Reply 23586 of 52822, by Batyra
Yes... if there only where white geforce 2 or 3... hehe I have also purple, blue red and black builds 😀 hmmmm... it can be a good idea... go! go! purple power! 😊
Reply 23588 of 52822, by oeuvre
Those Presarios had proprietary PSUs that are hard to find, just FYI in case you ever need a new PSU well good luck
Reply 23589 of 52822, by wiretap
Luckily it still works just fine, but if it ever dies I would just repair it. 😀
My Github
Reply 23590 of 52822, by OldCat
Okay, I usually try not to boast, but... BEHOLD:
52.78 KiB
Does anyone recognize this beauty in blue?
Reply 23595 of 52822, by The Serpent Rider
614.49 KiB
772.33 KiB
890.42 KiB
1016.21 KiB
568.99 KiB
Reply 23597 of 52822, by CarlHopkinsUK
Isnt this a Force Feedback mouse? Cant remember the name tho...
Reply 23598 of 52822, by The Serpent Rider
Pretty BF6 with nice cooler
That's an odd one actually: it's BE6-II (Highpoint RAID) with BF6 marking for some reason. Also it's revision 2.0 board with UDMA100 RAID.
Reply 23599 of 52822, by rikukos
Canopus Pure3D LX (sealed). I haven't seen this one sealed before. The seller I bought it from apparently had two of these but sadly I missed the first..I believe the one I missed will end up back in the big market place in not so distant future (albeit for a much higher bin price). Just my two cents 😉
