Reply 23600 of 52813, by oeuvre
An IBM Aptiva 2176-C73, Pentium 200MMX, 16MB RAM (upgrading that), 3.2GB HD, 2MB ATI Mach64 GT onboard, IBM MWAVE (shudder) modem/sound combo. Also bought a Matrox Mystique 4MB for it.
I have a Yamaha YMF-719 and a Novell NE2000 clone sitting around so I'll toss those in there. Selelr's pic
    83.98 KiB
Reply 23601 of 52813, by BeginnerGuy
My brother had a very similar Aptiva [I just asked, had had a p133]. Was a nice looking machine. It came with a "not for resale" version of Cyberia, I still have that laying around somewhere.
Sup. I like computers. Are you a computer?
Reply 23602 of 52813, by dionb
The Serpent Rider wrote:
Pretty BF6 with nice cooler
That's an odd one actually: it's BE6-II (Highpoint RAID) with BF6 marking for some reason. Also it's revision 2.0 board with UDMA100 RAID.
And that in a BX133 box...
Reply 23603 of 52813, by bjwil1991
My grandpa has the 2168-M55 that has 16MB RAM, 2GB HDD, Pentium 100, 2MB Trident video onboard, the IBM MWAVE sound card, 56K modem, and running Windows 95 (OEM). Still works to this day.
Reply 23604 of 52813, by OldCat
CarlHopkinsUK wrote:
OldCat wrote:
Okay, I usually try not to boast, but... BEHOLD:
Does anyone recognize this beauty in blue?
Isnt this a Force Feedback mouse? Cant remember the name tho...
Yes! The prize goes to the gentleman from UK! It's Logitech iFeel MouseMan, a very rare specimen indeed. Like regular iFeel, a vibrating mouse, but in MouseMan form factor. Really wanted one in 2001, but couldn't afford it.
A couple of links for your reading pleasure:
https://www.cnet.com/news/logitech-gets-touch … with-new-mouse/
http://www.dansdata.com/ifeel.htm
and a lot of drivers and modern-day info:
https://msrepurpose.wordpress.com/featured-one/home/about/
Reply 23605 of 52813, by The Serpent Rider
That's actually original box. I've checked serial numbers. BX133 stands for overclocking guide in the manual.
Reply 23606 of 52813, by chose007
You right, never seen this. Interesting about marking.
Reply 23607 of 52813, by dionb
meljor wrote:
I have three p5a-b boards and four p5a, all revisions. Tried two k6-3+ cpu's and two k6-2+. Getting any of these combinations with working cache above 630mhz i had zero luck. I also have the Gigabyte late revision (5.2), it is not better in any way as far as i know. Didn't even clock any higher as the Asus. It even was a fraction slower in benchmarks. The Gigabyte Ga5aa (baby at version) did a bit better but also slower as the p5a boards.
The absolute highest 3dmark scores i got from a 1.04 P5A-B
So good luck reaching 720mhz! Let me know if you got it.
Good news: got the board. It is a P5A Rev 1.04 with E-revision Aladdin V, so pretty much the best it could have been for K6plus.
Didn't get near 720MHz though. The board is rock solid at 120MHz FSB, but my CPU is limiting. The best I could get out of it was 633MHz, i.e. 5.5x115MHz - but to get that stable needed 2.5V, and I'm not about to run my K6-3+ at that sort of voltage for any period of time. So now it's chugging along at a respectable 5x120MHz at 2.1V.
The obligatory pic:
I'm impressed by the monitor (Compaq v55 612T); its specs are absolutely nothing special (1024x768@75Hz...), but the build quality is excellent, the picture sharper than .28 dot pitch would lead me to expect and the electronics very fast (syncs almost instantly). Even though it doesn't come close to my Iiyama 17" Diamondtron in terms of image quality, for DOS the Compaq might just be the better monitor.
Reply 23608 of 52813, by The Serpent Rider
Board itself maybe, but peripherals might start to go bonkers at 40mhz PCI.
Reply 23609 of 52813, by Turbo ->
Yesterday I got a working black & white 12" (29cm) monitor. Check it out:
    346.6 KiB
    356.07 KiB
    338.6 KiB
Reply 23610 of 52813, by oeuvre
eww MWAVE
First thing I'm doing to mine when it comes is swapping out the MWAVE with my trusty Yamaha YMF-719
Reply 23611 of 52813, by The Serpent Rider
998.57 KiB
861.6 KiB
927.54 KiB
822.43 KiB
880.02 KiB
Reply 23613 of 52813, by Batyra
Some new beauties!
Roland SSC-1
91.63 KiB
Roland SSC-1
Roland RAP-10 (with MCB-10)
95.78 KiB
Roland RAP-10
MediaTriX Audiotrix 3D-XG 😎 (bundle with speakers)
120.25 KiB
MediaTriX Audiotryx 3D-XG
Reply 23614 of 52813, by Predator99
Just won this auction...who else was bidding on it? 😉
1.08 MiB
...because I spotted this interesting part 😎 Unfortunately the brackets are not available any more...
602.17 KiB
Reply 23615 of 52813, by jheronimus
Why people throw out the brackets is honestly the biggest mystery to me in this whole hobby. Is it to save space when storing this cards? Do people use them to cover empty slots in PCs? Why do you need to remove the brackets?
MR BIOS catalog
Unicore catalog
Reply 23616 of 52813, by cyclone3d
The lamo scrappers remove them so they "can fit more in a shipping box".
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 23617 of 52813, by Predator99
Indeed good question. I assume people think they increase the value or they can give a more accurate weight when already removing the "non-gold" parts from such scrap piles?
Or they sell the metal separately? But this gives only few cents and make lots of work...
Should tell the seller that this sound card would have been worth around 150€ when sold separately with bracket...
Reply 23618 of 52813, by bjwil1991
I've used some of the brackets that were on certain cards to cover the empty slots in my PCs since the cards I had were way beyond repair and had divots on the boards themselves. I have a Riva TNT2 card that still needs repair, but, I still have the bracket for it. Other times, I use them to house RS-232 or serial ports on a bracket that was used on a VGA card (fits perfectly) in case one of my PC cases doesn't have a spot for one (AT cases) or too lazy to remove the metal shield of where the serial and parallel ports go onto.
