Reply 24760 of 52793, by stamasd
debs3759 wrote:
stamasd wrote:
My Alpha streak continues. Aspen Systems Inc. Telluride motherboard, for Alpha AXP21064A CPUs, 7PCI/2ISA (1 shared), full AT size, can take single or dual AT power supply, has FDC but no HD controller. It's a pain to find information about it.
I would have snapped that up if I collected non x86 stuff still. Lovely board for a nice price from the most reliable source I know 😀
Yah, now I have to find a CPU for it. Because the only one I have that fits is:
1. Already in use
2. It's a WinNT-only CPU. Yes, there were Alpha CPUs that were only able to run NT, not Unix (have a cut-down memory management unit).
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 24761 of 52793, by MCGA
I finally HAS tEh joystick for my old PC that doesn't suck.
The CH Flightstick Pro.
My favorite X-Wing joystick from my all time favorite joystick company. It works great! It was covered in some yellow goo, but I cleaned it up with contact cleaner and alcohol. I might have to go inside though to make sure it's clean. There's a tiny incy bincy tiny little small next to none dead-zone, but it's not causing me a problem. This could be how it always was and I'm just used to my newer CH joysticks -- which don't have a dead-zone that I can perceive.
Edit:
And I own X-Wing. So everything is legal. 😀
    341.95 KiB
Reply 24762 of 52793, by detritus olentus
Today's flea market find, I don't know how retro you all consider it to be but it is certainly an endangered species. Planning to replace the the 30GB toshiba drive with a Kingspec 120GB ZIF SSD.
    1.8 MiB
    Long live the Zune!
https://archive.org/details/@detritus_olentus
Philly Burbs.
Reply 24763 of 52793, by liqmat
MCGA wrote:
I finally HAS tEh joystick for my old PC that doesn't suck. […]
Edit:
Can you show a wider angle on that computer case with the dazzling red lights? Looks like an interesting case.
Reply 24764 of 52793, by Intel486dx33
Lian Li Aluminum case for my Super Socket 7 AMD K6-3 500mhz. Voodoo-3 gamer build.
Only $19 U.S.
    80.26 KiB
    71.79 KiB
    83.26 KiB
    64.84 KiB
    69.27 KiB
Reply 24767 of 52793, by appiah4
Only $19
Are there mATX SS7 boards? *smh*
Reply 24768 of 52793, by luckybob
appiah4 wrote:
Only $19
*cough*
http://www.acme.com/build_a_pc/boardfinder/se … _form=micro_atx
Reply 24769 of 52793, by appiah4
luckybob wrote:
appiah4 wrote:
Only $19
*cough*
Wow, you learn something new every day! *goes hunting for more socket 7 boards*
Reply 24770 of 52793, by Intel486dx33
I might have to mod it a bit. But I think if I use 300-watt SFF power supply on top, I can slide part of the Baby AT SS7 mother board underneath.
It's a baby AT motherboard ( Soyo SY-5EHM ) very small.
All I need is the AGP and PCI slots.
That will give me An AGP and 2 PCi slots and 1 slot for the Serial / Parallel cable back plate.
Slot 1 - Voodoo-3 AGP
Slot 2 - Sound Blaster Live 5.1 PCI
Slot 3 - Network card - PCI
Slot-4 - Serial mouse / Parallel port back plate.
I could even fit the serial and parallel cables under the power supply with a custom cover.
I will have to make some custom back covers to cover up any cavities.
I know it is not going to fit as intended but it should work.
What do you think ?
    156.54 KiB
    23.24 KiB
    136.46 KiB
    54 KiB
Reply 24771 of 52793, by Bancho
appiah4 wrote:
Only $19
Yeah.. I have one for my SS7 Build 😀
Reply 24772 of 52793, by Intel486dx33
I might have to go with a Socket 462 motherboard.
AMD Athlon 1ghz.
    185.83 KiB
    27.61 KiB
    1.19 MiB
Reply 24774 of 52793, by MCGA
The daszzing lights are from a Gotek Floppy emulator and a SD-to-IDE adapter -- which is behind the bay-screen-cover( which came from an old Antec tower.).
The case(computer) is an AT&T which I painted. It was one shade of light beige when I bought it. I painted the front drive area black and the case cover a darker beige. I prefer the many shades of beige for my older PCs. Even my thumb-usb-drive is beige. 😀
    347.2 KiB
Reply 24777 of 52793, by stamasd
luckybob wrote:
appiah4 wrote:
Only $19
*cough*
Too bad that search page doesn't cover anything older than SS7.
I/O, I/O,
I/O, I/O
Reply 24778 of 52793, by cyclone3d
luckybob wrote:
@Intel486dx33
permanent mods are sacralige. Id make a i/o shield with the serial/parallel.
Heh, you would probably want to kill me then if you saw what I did to my Lian Li PC-767 (from 2005)
31.93 KiB
I got it for $25 used at a local computer shop. The only fan mount was for a single 120mm. Well that wouldn't do for using it for my current build (i7-4930k based, R9-390, etc.)
I ended up putting 2x 120mm intake fans in the side cover to blow cool air into the case where the video card is.
I also added 2x 180mm intake fans to the bottom of the case and made some extensions for the feet out of wood so that there was room to mount the bottom intake fans.
And the last thing I did was to replace the stock USB/FW port on the side of the case with USB3. I did have to modify the original cutout.
Not sure if I will ever change my main case now that I have this setup as it works really good.
I do have a full tower Lian Li (RocketFish branded) waiting for me when I go to visit family though. Picket it up off of Craigslist for $20 and had my sister go pick it up for me. I might switch to that and use this case for another build but not sure.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 24779 of 52793, by bjwil1991
Cool looking case there, man.
