Reply 25800 of 52976, by xjas
Wow, I don't think I've ever seen a DVD-RAM disc or dedicated drive in the wild. Love those caddies too.
I kind of wish caddies for optical media had taken off. I understand why they didn't ($$), but it makes storing & using them so much more convenient.
Reply 25801 of 52976, by chose007
Yep they were very expensive. Just now I'am playing with it, classic CD/DVD working, DVD-RAMs not reading. Maybe need software, need search more information about.
You can use cartridge or without it.
Reply 25802 of 52976, by arncht
a NOS case with "97" style.
Hercules Terminator 3D/DX 4M PCI S3 ViRGE/DX
    305.94 KiB
    1.61 MiB
Overdoze of the demoscene
Reply 25804 of 52976, by Predator99
Predator99 wrote:
Just got this as a part of a (overpriced!) lot...: :depressed: […]
Just got this as a part of a (overpriced!) lot...: 😢
The attachment mgavlb.jpg is no longer available
Dont know if this was a good deal, but this one
http://www.vgamuseum.info/index.php/cpu/item/ … ima-ultima-plus
seems to be quite cool and unique.
Whats the upper card? Ethernet? There are 3 of them...anybody recognizes the logo with the dots?
Arrived today:
994.64 KiB
Beautiful card, but...
350.63 KiB
...looks like it has already been fixed? 😐
The other card is indeed a Thomas Conrad Ethernet. I like these, but unfortunately they dont have a ROM socket and TP-connectors:
1006.4 KiB
From another cheap scrap-lot 😎
1.02 MiB
Reply 25805 of 52976, by arncht
appiah4 wrote:
Amazing case, where do you keep finding these 😕
A company bought it many years ago, but they never used it.
Reply 25806 of 52976, by cyclone3d
Whoever did the soldering on that video card completely botched it up. It is very easy to see that some of the legs are soldered/shorted together.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 25807 of 52976, by Intel486dx33
Some no-clean flux and a heat gun should clean that up.
https://www.ebay.com/itm/SRA-312-No-Clean-Flu … S!-1:rk:52:pf:0
Reply 25808 of 52976, by bjwil1991
I use no-clean flux when I either reflow the solder, remove solder using the solder wick or desoldering iron, or make the soldering work faster.
Reply 25809 of 52976, by bestemor
I would assume just _reading_ a (formatted) RAM-disc with something on it should work in any DVD drive, regardless of software. As long as the drive itself has reading ability (check status with a program, Nero DiscSpeed or Opti Drive Control etc). I guess(!) it would be treated as any old DVD disc.
But if the disc is brand new and empty, then you have to format it, before transferring files (via winXP, not sure about win98), AND first install a driver for the OS of course.
I've gotten 'DVD-RAM Driver 5.0.2.5' to work in XP, formatting and writing to the disc. And also found a driver for win98('LF-D311' for Panasonic drive), not tested any writing, as current drive(in the win98 PC) does not have that option ticked (when analyzed by software). Non-caddy version (4.7gb Panasonic discs).
As for operations in DOS etc, I have yet no clue though, untested... Was more than hard enough to make it work in XP... 😵
Some drivers from ftp.panasonic.com, not really tested (+pdf 'manual' located a few lines above):
95.72 KiB
Reply 25810 of 52976, by Predator99
Yes, I will remove that with my desoldering gun and report. But if the previous owner turned it on in that state it is most likely trash anyway...
Reply 25811 of 52976, by bjwil1991
Good luck, man.
Reply 25812 of 52976, by Thallanor
I received something in the mail today from liqmatrix!
Motherboard w/ a 486 DX4-100! Yesss!
395.13 KiB
Oh! There's more stuff in the box!
Huh. What goes there?
384.58 KiB
And what are these for?
302.14 KiB
O-Oh, I see!
226.66 KiB
MV5BOTQ2N2I5MDgtODA0NC00M2NmLWIyNzAtNjNlYTQxYWQ4ZTQzXkEyXkFqcGdeQXVyMjA3NDg2Mzg@._V1_.jpg
75.38 KiB
I'm super excited! There were also some AT backplanes in the package, along with P3-1000 and P3-1266 CPUs and a new Intel NIC. 😀 Will probably save all of this for when the cold weather hits and turn these into winter projects. 😀
Reply 25814 of 52976, by dionb
Was away for almost a week and came back to find some parcels had arrived...
Despite the underwhelming performance, I've always had a weak spot for VRAM and mid 1990s Diamond boards, so had to go for this upgrade Stealth3D 3000 (Virge/VX).
Then there's the Matrox lot on the right. Had sort of hoped the G400 was actually a max that had lost its fan, but no, just a regular G400. The Parhelia 512 -128MB is pretty neat though.
Further back there's the SB16, a CT2910, so a real OPL3, a good low-noise CT1703-A and best of all: non-PnP, all resources can be configged by good old jumpers.
Also got a GoldenOrb rip-off, not from Thermaltake, but the design looks identical. That thing is going on some or other P3.
Reply 25815 of 52976, by Intel486dx33
I have one of those and it's really loud. I don't like it. It's too loud. I am going to remove it and go with a standard heatsink.
I need a silent PC. My PSU is silent. Just the Thermaltake Golden orb is too loud. Maybe if you can get some sort of fan speed controller to slow down the fan because it spins at FULL speed.
Reply 25816 of 52976, by xjas
That Parhelia is a beauty. Nice score!
Always wondered why Matrox used those LONG VGA connectors. Was it extra shielding, did they hide ICs under there, or did they just want to move the pins farther back on the board? Anyone know?
Reply 25817 of 52976, by Predator99
Just learned...this is no ethernet..!
https://stason.org/TULARC/pc/network-cards/T/ … ary-TC3045.html
https://books.google.de/books?id=qRzjFB6Ic3oC … -conrad&f=false
Its a proprietary interface with 100mbit over the ISA bus 😎
Reply 25818 of 52976, by SW-SSG
xjas wrote:
... Always wondered why Matrox used those LONG VGA connectors. Was it extra shielding, did they hide ICs under there, or did they just want to move the pins farther back on the board? Anyone know?
Looking at photos of a G450, some models traded a VGA output for a DVI, and the DVI port's holes are positioned closer to the slot cover than those of the VGA's. The other VGA port seemingly could also be replaced but I'm not sure with what (S-Video jack, maybe?).
Reply 25819 of 52976, by gdjacobs
Apparently a high performance evolution of ARCNet. Cool.
I actually used to have a twisted pair ARCNet hub.
