Reply 25940 of 40034, by liqmat
boxpressed wrote:
STB Soundrage 32 with the AMD InterWave synth. […]
This was a difficult card to get up and running, and I have the original driver disks. I tried to set it up in a DOS-only build, and I couldn't get the card to initialize. Finally got it to work in a 98SE build but only after following the instruction sheet crashed my OS so bad that I had to reimage. You can run DOS games after exiting to DOS from Windows.
This card has only a 1MB ROM for the InterWave. It's not great but better than the cheaper synths and patch sets. I'll add it eventually to my dormant wavetable synth thread.
Are those original driver disks available for download somewhere? If not, could you image the disks and post them here? Thanks.
Reply 25941 of 40034, by Neco
xjas wrote:
^^ let us know how that does with standard VGA modes (especially 70Hz ones, e.g. 13h or other 200/400-line modes.) Looks like a useful little piece of gear if it handles those well.
It works...but its severely flawed, I need to talk to someone familiar with both this unit and Micomsoft SC-512N1-L/DVI and drivers.
Reply 25942 of 40034, by Predator99
Couldnt say "no" to this one (sellers picture):
23.27 KiB
Mainboard has battery damage, but price was really good. Therefore I also accepated that case.... 😵 Looks like painting a 100 year old car in pink color with yellow stripes.
He used with some kind of laquer. Looks really ugly. Need to find a way to remove that. Maybe with a heat gun from the metal part. But for the plastic cover..? Maybe with some chemicals. No idea at the moment.
Reply 25943 of 40034, by Neco
Predator99 wrote:
Couldnt say "no" to this one (sellers picture): […]
https://www.woodworkingtalk.com/f8/removing-l … -plastic-25374/
maybe that citris stuff ? Or you could try baking soda and very gentle / long hours ?
Reply 25944 of 40034, by yawetaG
^ Lacquer thinner, but it's foul stuff and will likely damage the case. Lacquers are usually quite immune to a lot of chemicals.
Perhaps this is useful for you guys and gals:
http://retrorgb.com/upscalers.html
Back when I looked into scalers, the Framemeister was basically the single best option (but very expensive), but it looks like it now has competition. All other scalers tend to suck.
(In the end I didn't need to buy one, as it turned out my Samsung TV would take any resolution via SCART, while the VGA and HDMI inputs were severely limited...)
Reply 25945 of 40034, by dionb
Oh dear... Spent a little too much on old crap again. Not even 100% sure what two of the four cards are exactly, but what was clear made it worth the risk. Will post pics when they arrive and I can fully identify, but for now suffice to say there's a lot of Tseng goodness coming this way 😉
Reply 25946 of 40034, by boxpressed
Here you go. The label reads:
STB SYSTEMS INC.
SOUND RAGE 32/3D
DOS/WIN 3.1X DRIVERS
DISK 1 OF 2
RELEASE 1.0
The Windows 95 drivers are already available on vogonsdrivers. Look for "AMD Interwave."
Soundrage DOS 1.7z
331.05 KiB
19 downloads
Soundrage DOS 2.7z
497.29 KiB
21 downloads
Reply 25947 of 40034, by boxpressed
The Serpent Rider wrote:
Does it sound any different when compared to GUS PnP?
Can't say for sure. I have only the GF1 GUS (Classic and Ace) and don't have the PnP versions.
Reply 25948 of 40034, by mmx23
After long searching, I finally found an ALR Revolution 2x server.
Two slotket's ( Slot 1 to Slotket 8 converter) with Pentium Pro 200 MHz 256KB cache,
4x128 MB ECC Edo Ram,
36 GB Scsi Hdd, 18 GB Scsi Hdd, 6 GB IDE Hdd, 3,5" Fdd,
Sony SDT-9000 DDS Scsi backup drive,
Nec MultiSpin 4Xi Caddy Scsi Cdrom drive,
Video card Matrox Millenium 2MB wram pci ,
3D accelerator Quantum3D Obsidian2 Sbi 24MB,
Mylex i960 Pci Raid controller 8MB cache,
Intel PRO 100+ dual port 10/100 ethernet card,
SoundBlaster AWE 32 Isa sound card
OS: Windows NT 4.0, Windows XP, BeOS 5
Enjoy
https://imgur.com/a/K53aX7k
    49.07 KiB
Reply 25949 of 40034, by liqmat
mmx23 wrote:
After long searching, I finally found an ALR Revolution 2x server. […]
Enjoy
Vogons member hard1k found a FTP site with the EISA config utility and other files for the ALR servers. A ton of Revolution BIOS files are in there as well. Don't know if this will help you or not.
http://solution.eisp.pl/resources/alr/
Reply 25950 of 40034, by henryVK
Heck yes. Got another Siemens PCD-4ND laptop off ebay for 23 euros.
Looks like it might be in good condition, battery is missing, no word on the disk drive which will likely need a new belt. I'm mainly getting this one in case my other one dies, and, hey, it was a steal.
Seller's photo:
Reply 25952 of 40034, by appiah4
Reply 25953 of 40034, by gex85
Diamond Sonic Impact S90. I never owned any soundcard based on an Aureal chipset before and got this one for less than 10€ (shipping included) on eBay.
I think it will go into my P3-650 build to replace the SB Audigy Platinum EX (SB0090) that no doubt is far more capable but to me feels a bit out of place in this system (P3-650 released in late 1999, SB Audigy released in late 2001, Diamond S90 released in late 1998).
1.28 MiB
1.23 MiB
1992 - i486DX2-66 // 1997 - P1-233 MMX // 1998 - P2-350 // 2000 - P3-650 // 2001 - Athlon 1400 // 2003 - Athlon XP 3200+ // 2008 - Xeon E5450 // 2015 - Xeon E3-1240v5
Reply 25954 of 40034, by Intel486dx33
gex85 wrote:
Diamond Sonic Impact S90. I never owned any soundcard based on an Aureal chipset before and got this one for less than 10€ (ship […]
That Vortex 3D sound is really cool when setup with good speakers.
I use my Klipsch Promedia 2.1 speakers.
But any 2,1 speaker setup should work fine.
Reply 25955 of 40034, by Intel486dx33
Some S/PDIF backplates to mod my sound cards with Tos-link optical.
Reply 25956 of 40034, by Rasna
mxTCVab.jpg?1
Updated the microcode and rom eproms to the latest version............. 😊
ouFvD50.jpg?1
8trTNJ8.jpg?1
8 meg extra
ddRAqYC.jpg?1
ET4000 32k colors
My MIDI modules: Roland MT-32 (old), CM-32L, SC-55, SC-55mk2, SC-88 Pro | Yamaha MU-100, SW1000XG | Akai SG01k | Kawai GMega | Korg NS5R
Reply 25957 of 40034, by OldCat
henryVK wrote:
Heck yes. Got another Siemens PCD-4ND laptop off ebay for 23 euros. [...] […]
Seller's photo:
Congrats! Great machine and great price. I'd buy that as well!
Reply 25958 of 40034, by mmx23
Enjoy
Thank's for the link, if anyone will need Infor Manager software (you may find a screen shoot in my Imgur pictures and below) just let me know.
Infor MAnager is ALR's (later rebranded in Gateway) hardware monitoring software.
    88.1 KiB
Reply 25959 of 40034, by xjas
That's weird, was that stock? Are they "true" Slot 1 slots or some proprietary thing that just looks like Slot 1?
If Slot 1 already existed when they made this, I can't imagine why they didn't just go with P2s and SDRAM. It's not like the Pros would have been any cheaper.
Neat system though, love the CD-ROM.
I should put my ALR7200 board to use...
