Reply 26000 of 40034, by Intel486dx33
PCChips motherboard with AMD Athlon and Via chipset. For a modern computer build to clock down and play 386 computer games.
    1.72 MiB
Reply 26001 of 40034, by sf78
I (almost) hit a jackpot today, I believe it's an 5950 Ultra and it cost me 5€. However, the last mosfet on the right side of the cooler is burned and I need to replace it before I can say if this thing actually works or not. Fingers crossed... 😊
255.79 KiB
Reply 26002 of 40034, by Predator99
Gold delivery:
1.02 MiB
Think I made a good deal, Pins are also OK. My first golden P75 😎 Hope they will work.
Reply 26003 of 40034, by SW-SSG
^At least two of those Intel 486DX2-66 look to be remarked. Makes one wonder what chips they actually are.
That one Intel 486 with the hole (?!) in its top is funny, too.
Reply 26004 of 40034, by Predator99
Indeed, the 2nd DX2 in the 3rd row looks rather unusual with its "matrix"-print on it.
There is some glue-residue on the bottom one. And its still soldered on the pcb from which it has been broken out. But CPU is still OK...
Reply 26005 of 40034, by blurks
The attachment fx.jpg is no longer available
Creative Labs' 5950 Ultra looks different, as it relies on nVidia's reference design (it might be a later revision based on MSI's design though):
445.43 KiB
Image (c) by Hardware.info
Reply 26006 of 40034, by Strahssis
I bought a brand new old ATX/AT-case complete in box on Marktplaats yesterday for only €13. It arrived today at my home and I'm very happy with it; the build quality is very nice and everything is included; including spare screws. It also came with this Deer Computer Co.Ltd 250W ATX power supply, which is also brand new and has never been used before. I have never heard of this brand though, has any of you guys ever heard of it? The power supply sticker indicates that it was produced in 2001, so I'm assuming the case was also made around that time. The power supply cable still has that very nice new smell though! 😀
1.85 MiB
1.85 MiB
Woepie: Intel Core i5 4460, Asus Radeon R7 240, Sweex 5.1 CMI8738, 16GB RAM
Syros: Intel Pentium 4 SL68R, ATI Rage 128 Pro, Sweex 5.1 CMI8738, 384MB RAM
Mimi: AMD K6-2/266, S3 Trio64, Diamond Monster 3D II, Creative Sound Blaster CT2800, 32MB RAM
Reply 26007 of 40034, by cyclone3d
Deer... the brand of PSU that causes your motherboard and other hardware to get the same look right before it releases the magic smoke that a deer gets before getting plowed into by a speeding car in the dead of night.
Yamaha YMF7x4 Guide
Epstein didn't kill himself
Reply 26009 of 40034, by Strahssis
Haha, then I guess this Deer is going to be new and unused for an extended amount of time. It will make a nice museum piece! 😜
Reply 26010 of 40034, by cyclone3d
Deer was basically the brand of power supply that came with cases back then. While they worked they were also super cheaply made. I would guess it would output about 1/3-1/2 of it's rated power before failing.
I also wouldn't trust the caps to not explode on first power-up as they have been sitting for a really long time.
Yamaha YMF7x4 Guide
Reply 26012 of 40034, by SW-SSG
Predator99 wrote:
Indeed, the 2nd DX2 in the 3rd row looks rather unusual with its "matrix"-print on it. ...
Yup, and I meant also the one directly above it. The black text looks "printed-on" and not slightly reflective like that of the others in the photo. After cleaning the top, it might additionally have an unusually polished-looking surface, indicative of the sandpaper (?) that was used to remove the original print.
EDIT: I'll assume Anonymous Coward below is talking about the one with "matrix print".
Reply 26013 of 40034, by Anonymous Coward
It's legit. That one is manufactured by IBM, and that's how they all look.
Reply 26014 of 40034, by appiah4
This. I also have one; it is functionally the same but manufactured by IBM under license. When the license expired they started manufacturing Blu Lightning CPUs licensed from Cyrix, functionally equivalent to their DX2s.
Reply 26015 of 40034, by Roman555
SSTV2 wrote:
Just got this AMD slot A motherboard/cpu combo, it's equipped with AMD Irongate chipset. DFI-AK70: Worst CPU VRM layout in terms […]
DFI-AK70:
Worst CPU VRM layout in terms of space-saving I've ever seen, bulgy caps also:
The big polygons help to dissipate heat. Otherwise mosfets heatsinks would be needed.
Reply 26016 of 40034, by sf78
Yes, it's an MSI card with the VIVO chip removed and Creative sticker stuck on the fan. 🤣
Reply 26017 of 40034, by maverick21
Finally got my hands on an affordable Monster 3D 2 with loopback cable and original Need for Speed 2 SE CD, which was bundled with the card! I just can't wait for the real experience. I'll try it this evening.
    257.87 KiB
    Diamond Monster 3D 2
Reply 26018 of 40034, by dionb
What's better than a Tseng ET4000AX? An ET6100. And what's better than an ET6100? Two ET6100 boards with some ViVo stuff too:
The ET4000AX is a pretty standard ("Britek") ISA card. The ET6100s are somewhat more special, two Integral Technologies Flashpoint 128 frame grabber/VGA combo cards, with an ET6100 and 4M of MDRAM (4x MD908). Lacking the proprietary video-in cables I can't grab any frames, but the ET6100 works perfectly on both cards. Oh, and the last card was supposed to be a Diamond Stealth III 540, but turned out to be a Speedstar A200 (same Savage4Pro, but only equipped with 8MB of SDRAM.
Reply 26019 of 40034, by Turbo ->
Today's acquisitions: DVD RW drive, 5,25" Floppy drive, serial mouse, High speed ISA serial port, ISA serial card and somewhat ISA card
    552.68 KiB
