Reply 26100 of 40033, by Munx
canthearu wrote:
In happier sound card news, I received this little gem today. A diamond multimedia sonic impact S90. […]
Based on a cheaper respin of the original aureal vortex 1 chip, the AU8820 is still pretty good. This example offers very nice line output quality and good DOS compatibility.
Considering I paid $24 AU delivered for it, I think I have done OK.
It is going into an Athlon XP-2000 based system with nvidia geforce 4ti-4200 😀
AU8820 IS the original Aureal Vortex. 8810 is the cheaper respin.
My builds!
The Underdog - The budget K6
Reply 26101 of 40033, by Thallanor
LHN91 wrote:
That second one looks like a pretty bog-standard YMF719 based card. I've got a Labway card that looks identical.
EDIT: By which I mean that generic Yamaha drivers should work just fine
Yeah. I might be on crack thinking that back in the day, Yamaha started building their own sound cards. My memory sure ain't what it used to be!
I Googled the FCC ID and tada! Labway. 😀 Good eye! A Google hit to VOGONS mentioned someone having trouble getting stereo sound out of its Sound Blaster Pro emulation, but I'll dig deeper when I have a chance. If it does good Sound Blaster Pro emulation, combined with it having OPL3 and an MPU-401 port, I could be in heaven. 😀 And it was a dirt-cheap card too. I was chatting with stamasd from the forums here and he's who got me interested in these cards again so it was sort of an impulse purchase. But for $20? Yeah, I'm cool with that. 😀 I was a bit nervous because the seller was Russian and I wasn't sure if I'd get the package mauled by Russian bears or anything, or if I'd receive anything at all. No box, but the guy must have shares in a bubblewrap company because there must have been 3" of padding all the way around it. I suspect it'd even survive that Russian bear.
Reply 26102 of 40033, by LHN91
Yamaha did make their own cards - the Yamaha Audician 32 is one example. The chipsets just also ended up lots of other places.
Reply 26103 of 40033, by appiah4
Nice finds. The AWE64s are CT4520s not 4620s (Not sure if 4620s exist..). The SB32 is basically an AWE64 with 30 pin SIMM slots and an IDE interface. That means no bug on the MPU-401 but no daughterboard either. The YMF card is a Labway indeed.
Reply 26104 of 40033, by arncht
1999 july fun 😀
spare asus p3b-f for my p3 rig
p3 600 the fastest katmai
creative tnt2 ultra
i updated my benchmark table:
https://docs.google.com/spreadsheets/d/1eXksI … dit?usp=sharing
    1.77 MiB
Bought this retro hardware
Reply 26105 of 40033, by KCompRoom2000
Exactly as I suspected, there's such as thing as a CT4620, but it's a Sound Blaster Live, not an AWE64. The image on Thallanor's post shows that the cards he has are CT4520s (I could see their model numbers clearly).
Also, if you find yourself wanting to get rid of the IDE interface capability of the CT3670, you can flash AWE64 firmware on it to remove the IDE function, which makes sense if you're dealing with a newer (Pentium era) machine that already has two IDE ports: How I turned my CT3670 into an AWE64 and got rid of its pesky IDE interface
Reply 26106 of 40033, by Vegge
Last weeks purchases 😀
First out, another awesome AT-fulltower 😀 The base for the case is removed to avoid braking in transport.
1.01 MiB
PSU is dead, but EISA power and 5.25" fullheight scsidisk! 🤣
1.41 MiB
VLB SCSI and DX4 100
516.92 KiB
Random external cd
989.32 KiB
Joindata-bus ET4000AX, now I only need to find the matching motherboard
1.4 MiB
That's all for now, some other bits and pieces on the way 😀
Reply 26107 of 40033, by appiah4
About to order this motherboard, found it listed locally at a misprice..
I also have an EPI-M 10000G but that one has an audio codec with no SB Pro Legacy compatibility; this unidentified board looks like an older mITX that would have DOS audio.. Anyone know what the board is? Searching for VT133 got me to several mATX boards of the exact same layout by PCChips/ECS (PCCHIPS M787CLR (ELITEGROUP P6VEM2 - VIA 1 Giga Pro) VIA C3 Samuel 2) but I can't seem to find the model number for the mITX version.
Appears to be a SiS 630 chipset and VIA VT1612A AC97 codec? That VIA sound codec is SB Pro Legacy compatible, so this should be pretty good for an mITX Win9x/DOS build?
Reply 26108 of 40033, by Thallanor
Oops! My bad! You are correct on the model number. 😀
Reply 26109 of 40033, by Thallanor
Excellent! I'll take a peek, thank you!
Reply 26110 of 40033, by canthearu
1.94 MiB
My next repair project
Socket A motherboard - Gigabyte GA-7ZXE motherboard. A nice Athlon/Athlon XP motherboard with built in SB emulation via the VIA chipset.
Current Status: Boots, but isn't particularly stable. Has 7 bad capacitors.
To be replaced
5 x Choyo capacitors, XG series, 3300uF 6.3V. Can't find specs. I'm going to take a wild stab in the dark and replace these with Panasonic OS-CON polymer capacitors, 1500uF 6.3V, based on the fact that this series is probably the Ultra low ESR series motherboard capacitors.
8 x Choyo capacitors, XR series, 330uf 25V. For these smaller capacitors, I'll go with Panasonic FM 330uF 25V electrolytic capacitors.
1 x Choyo capacitor, XR series, 1200uF 6.3V. I think Panasonic FM 1200uF 6.3V will be perfectly fine for this too.
Reply 26111 of 40033, by dionb
SiS 630 and Via codec? This is a pure Via board with Via southbrige visible and C-Media CM8378 onboard PCI sound. The Northbridge print reeks of PC-Chips. CM-8378 has DOS drivers (via TSR), so should be OK for your purposes.
Reply 26112 of 40033, by liqmat
Vegge wrote:
Last weeks purchases :) […]
Random external cd
Wow. Some nice hardware there. Great case and a VLB SCSI card. Very cool and it all looks very clean.
Reply 26113 of 40033, by appiah4
Good enough for me 😀
Reply 26114 of 40033, by Predator99
Very nice tower and board, Vegge! 😎
For me RAM-day:
1.03 MiB
Many 30-pin Simm, also 4MBs and some Coast-Modules. Great Deal for 45€ shipped 😎
Reply 26115 of 40033, by The Serpent Rider
Is that a terminator COAST module on the left side?
Reply 26116 of 40033, by Predator99
Good question. Dont know what it is. As far as I know you can leave the slot empty, no need for a terminator? But Pinout matches excatly.
Reply 26117 of 40033, by Intel486dx33
This has been bouncing around in my garage.
Sony CDU926s SCSI 2x cd-r with ISA Adaptec controller 1505
For a 486dx-66 or higher CPU with 16mb ram.
Back when Sony Corp. had several manufacturing and repair facilities in Silicon Valley.
I don't know if they are still there ?
    153.02 KiB
    124.37 KiB
    116.19 KiB
    138.21 KiB
    128.23 KiB
Reply 26118 of 40033, by bjwil1991
What year did that drive get released? Very interesting.
Reply 26119 of 40033, by Intel486dx33
The Box reads printed 3/98
So it's not too old. Does have a caddy for the cdrom.
    119.32 KiB
