Reply 28420 of 40040, by bjwil1991
Bought the following from 4/26-4/27:
Gravis Blackhawk (not digital)
Sega Genesis Model 1 High Definition Graphics model
4.1 Surround speakers (complete in box)
The Genesis needed some TLC to get the system to load cartridges, and fortunately, no broken pins and everything is still good. Might do a recap sometime soon, and I had to buy a power adapter and AV cable to test it to make sure it turns on and it does indeed work.
Reply 28421 of 40040, by liqmat
I used to have a large collection of titles for the Genesis. The rare ones went to a museum and the rest I sold off. One of my favorite titles for the console is this and I highly recommend it. Especially two player is a lot of fun. Pounding soundtrack as well.
https://youtu.be/GRV8jwEfUrs
The biggest weakness of the model 1 is the cart slot.
Reply 28422 of 40040, by bjwil1991
Is there a major difference between the Model 1, 2, and 3 for games, such as sound? There is a video comparison between Model 1, 2, 3, and CDX: https://www.youtube.com/watch?v=jjCOlnGpi1g
Also, for the Model 1 cart slot issue, would replacing the slot itself suffice?
Reply 28423 of 40040, by liqmat
Supposedly the model 1 "high definition graphics" version has the best sound. The one you have is the most desirable. Just use the cart slot until it wears out, if it does. Some of the later model 1s had a better quality slot. Honestly wouldn't mess with it if it's working fine. I would clean the slot pins though. Credit card or similar plastic card wrapped in a rubbing alcohol soaked thin cloth is how I did it. Just insert that a couple of times and wait a few minutes for the alcohol to dissipate.
https://youtu.be/RU4Qb4g3hwY
Reply 28424 of 40040, by Dragon Caesar
A neat thing with the Genesis is that it supports RGB out without any modding for crystal clear video. Only downside is this can lead to a rabbit hole of buying converter boxes and/or upscalers. A company called HD Retrovision offers a Genesis to component out cable as well. https://www.hdretrovision.com/genesis
Reply 28425 of 40040, by MCGA
I'm trying to fix my model 1. The chips I ordered from China showed up today, so hopefully they'll address my sound cutting out after a period of time. I had already swapped out the one of the other chips after reading a thread of a similar problem, but it didn't help. I also have a model 2 that's broken. I swapped out its cartridge slot so far, and no luck. I'm new to this stuff, so I'm just shooting in the dark as I get practice soldering.
Reply 28426 of 40040, by badmojo
I discovered this Retrovision cable recently and love it - I'm using a Retrotink to HDMI->VGA converter to a VGA CRT and wow, the image is spectacular. But yes, it was quite the rabbit hole and I'm still going down it - I have a scanline generator on the way 🤣
Reply 28429 of 40040, by meljor
Bige4u wrote:
My VooDoo AGP versions collection is now complete!
Voodoo3 2000 / Voodoo3 3000 / Voodoo4 4500 / Voodoo5 5500
No cutting corners here: you need at least a Banshee agp and a 3500tv agp to make it more ''complete''. Ofcourse you can go further and search for the v3 1000 agp, the Velocity models and ofcourse the Quantum3d cards.
Beeing ''unoptaniums'' I skip the voodoo5 6k and Rampage for you....
So...grab your coat and get out there again! 🤣
Reply 28431 of 40040, by Bige4u
meljor wrote:
No cutting corners here: you need at least a Banshee agp and a 3500tv agp to make it more ''complete''. Ofcourse you can go furt […]
Im happy with what i've got, i need nothing more... im content.
Pentium 200/ Biostar M5ATA / 2 x 32mb EDO / Seagate 3.2gb 5400rpm / Diamond Stealth3D 2000 4mb / SB16 CT2980 / 40x cdrom / 3.5'' Floppy / Solar Power 250w / Win95c
Reply 28432 of 40040, by appiah4
Bought this card because it was on sale for $1.50 and looked interesting. The only cards with this kind of dual feature connectors that I know of are the Banshee and i740. My bet is on Banshee. Does anyone know what this card really is?
    241.9 KiB
Reply 28433 of 40040, by kixs
stalk3r wrote:
kixs wrote:
It will run in slow motion... around 1.5 to 2 FPS 😉
2 FPS is an overly optimistic estimate, I believe 😀
Depends on the CPU used.
Reply 28434 of 40040, by havli
Hard to say what card exactly, but I'm 90% sure it is not Banshee. Banshee is using different memory layout and most of the time PCB is not ready for TV-OUT.
Reply 28435 of 40040, by appiah4
Well.. There are Banshees with this layout(with 4 chips on th eback) so I thought it may be something similar:
Any other ideas? It's a fun guessing game. Googling the FCC-ID leads me to a Cardex card in some OEM PC but I can't find much more on it.. Searching FCC results in a few Gainward cards..
Reply 28436 of 40040, by RandomStranger
This made me curious. The ID (ICUVGA-GW7**) number says it should be a Gainward card, but it isn't fully visible.
What I find with similar IDs are:
703 - Voodoo 1
707 - Voodoo Rush
710 - S3 Virge
But this is neither of these.
The Banshee is similar looking (https://i.ebayimg.com/images/g/l6UAAOSwGNxbHDSP/s-l1600.jpg), but it's GW816DP.
Reply 28437 of 40040, by havli
Maybe Permedia? http://www.vgamuseum.info/index.php/cpu/item/ … abs-permedia-2v
The Gainward one looks similar, but it isn't this exact card.
Reply 28438 of 40040, by RaverX
I'm 100% sure that it's not a Banshee.
I'm also 95% sure that's a S3 Virge.
It could also be S3 Savage4.
There's a low chance that it could be Riva128 or i740.
Reply 28439 of 40040, by SpectriaForce
Looks like a S3 Virge/GX2 (highest probability), S3 Savage4, i740 or Riva 128.
It’s certainly not a Voodoo card.
Now huge discounts on custom made, clean, tested, retro game pc's.
