Reply 28560 of 40040, by mpe
The early ceramic P60 has cost me an arm and a leg but at least my Socket 4 collection is growing.
1.58 MiB
Blog|NexGen 586|S4
Reply 28561 of 40040, by HanJammer
Tetrium wrote:
Vynix wrote:
Tetrium wrote:
Are you sure about VX supporting only 1 DIMM slot?
Perhaps some VX mobos only had 1 SDRAM slot, but some had two... Take for example my Shuttle HOT-555A, it has two DIMM slots, but is capped to 32mb, per DIMM.
Iirc most didn't have any DIMM slots and if they did, they had just 1.
I actually thought 2xDIMM slots was more a TX thing until I saw a VX board with 2 DIMM slots, but it was easy to think VX boards simply came with only 1, if at all.
Overstatement.
Many boards had two DIMM slots.
Another VX sample (DTK PAM-0065I) arrived today (and a rather early one for that matter). 2 DIMM slots...
Check out my YouTube channel the "Rusty Bits"
Reply 28562 of 40040, by appiah4
These two set me back about as much as a lunch so I thought why not..
Reply 28563 of 40040, by Intel486dx33
Bought a couple Cooler Master fan speed controllers for my "Ultimate Windows 98 builds"
These are going into Lian Li Silver Aluminum cases to control the case fans, CPU fan, and Voodoo-3 video card fan.
They are going to look Awsome !
These display the temperature and fan RPM's.
Reply 28564 of 40040, by mothergoose729
Just pulled the trigger on an ASRock 775 Dual VSTA!
https://asrock.com/mb/VIA/775Dual-VSTA/index. … p#Specification
It supports Core2Duo processors and AGP at 1066mhz! To my knowledge, this is the fastest motherboard with an AGP slot.
I am going to pair it with a intel 6500k, which is a pentium dual core with an unlocked multiplier! Because I am going crazy, might as well try for a 4.0ghz overclock too. Why not.
I have a 256mb 7800gtx and a Quadro FX 2000. I'll be using the Quadro, but it will be fun to try some benchmarks with the 7800gtx and DDR2 memory.
Reply 28565 of 40040, by JonathonWyble
Sometime next week I will receive this power supply. This is going to be another component for a retro rig I'm working on.
1998 Pentium II build
Reply 28566 of 40040, by arncht
liqmat wrote:
arncht wrote:
What is the chipset of the paradise? Ark2000?
So yes, it is detected as an ARK2000PV chipset. It only has 1MB (exp. to 2MB), but man, in benchmarks this thing is only a hair slower than the 4MB Matrox Millennium which is one of my best DOS PCI performers. Both of them outpace the 32MB Savage 4 in DRHARD benchmarks.
The millennium is slower than the et6000 or the riva128. I measured it is on similar level than the s3 in socket 7, and slighly slower in socket 5.
Bought this retro hardware
Reply 28567 of 40040, by liqmat
I guess my point is I was surprised that little Paradise card performed as well as it did. I was expecting more Trident level results. It will certainly do just fine for 2D games. It has been a couple of decades so I had forgotten just how bad many of the Trident cards perform.
Reply 28568 of 40040, by appiah4
I have an ARK1000 and it is also an amazing DOS performer as well.
Reply 28569 of 40040, by HanJammer
True. I benchmarked ARK1000 against several other PCI 2D cards and nothing came even close in my tests.
Reply 28570 of 40040, by appiah4
What improvements does the ARK2000 have over the 1000? MPEG decoder perhaps? Does anyone know? Never did find any spec sheets for either chip.
Reply 28571 of 40040, by arncht
2000pv - 64bit
2000mt - mpeg acceleration
with a 233mmx under dos
https://docs.google.com/spreadsheets/d/1eXksI … MVZU/edit#gid=0
My actual PCI card ranking:
94,44% Diamond Stealth 64 Video 2001 2M PCI S3 Trio64V+
94,81% Hercules Terminator 3D/DX 4M PCI S3 ViRGE/DX
95,40% Matrox Millenium 4M PCI
99,33% Hercules Dynamite 128 4M PCI Tseng ET6000
99,45% Hercules Dynamite 128 2M PCI Tseng ET6000
100,00% Asus 3DP-V3000 4M PCI NVIDIA Riva128
Reply 28572 of 40040, by appiah4
I guess 64-bit and MPEG Acceleration could be useful for Socket 5 or thereabouts but for 486SX/DX/DX2 I'd bet they are essentially useless..
Reply 28573 of 40040, by liqmat
arncht wrote:
2000pv - 64bit 2000mt - mpeg acceleration […]
2000pv - 64bit
You are much more organized than I. Although, I don't collect and just try to find homes for my orphans. I will admit I am rather shallow. I really go for physical appearance rather than performance when it comes to video cards as I am rarely going to use any of them. That recent ET6000 you picked up is just beautiful to look at. If I didn't move around so much I would probably have some framed and on a wall.
One of my favorite cards with good looks that I have acquired is the Number Nine Imagine 128 Pro. This card has since gone to Merovign's collection since I just can't keep this stuff.
1.42 MiB
Reply 28574 of 40040, by arncht
yeah, they are really nice. i just hope, the quality is better, than the hercules cards 😁
Reply 28575 of 40040, by Cyrix200+
liqmat wrote:
<snip>
My god it's perfect.
1982 to 2001
Reply 28576 of 40040, by liqmat
Yeah, like so many "Pro" cards of the time it had horrendous DOS performance, but was really good at specific software packages like CAD.
Reply 28577 of 40040, by Artex
FDIV! 😎
Click [here] to see my collection of retro bliss!
Click [here] to see my "I just gotta have it"' list!
Reply 28579 of 40040, by luckybob
As someone who has recapped KA7 in the past. This board is HIGHLY sensitive to bad caps. The missing atx connector is a bit odd.
if you do recap it, make sure you get the lowest ESR you can.
