Reply 28580 of 40040, by bofh.fromhell
luckybob wrote:
As someone who has recapped KA7 in the past. This board is HIGHLY sensitive to bad caps. The missing atx connector is a bit odd.
if you do recap it, make sure you get the lowest ESR you can.
Presumably someone has used it for spares once the caps got bad enough to stop POST.
Apart from the ATX connector I also spot the missing battery holder.
Once I get it I'm gonna do a thorough check over before I spend any real time or components on it =)
Reply 28581 of 40040, by brassicGamer
mothergoose729 wrote:
Just pulled the trigger on an ASRock 775 Dual VSTA!
https://asrock.com/mb/VIA/775Dual-VSTA/index. … p#Specification
It supports Core2Duo processors and AGP at 1066mhz! To my knowledge, this is the fastest motherboard with an AGP slot.
I like these boards, they're very versatile. I have the S478 version because I couldn't afford to replace my Radeon 8500 at the time, so the PCIe gave me the option. It's a nice middle ground between legacy PIII/P4 hardware like IDE, DDR2, AGP and later tech such as PCIe, SATA and dual channel RAM. They last forever and the range of components you can hook up to it is as long as your arm, as they say.
Reply 28582 of 40040, by gdjacobs
bofh.fromhell wrote:
Snagged an ABIT KA7 for peanuts.
Obviously the caps are all OK, as seen on the pic 😉
Caps work better when they bulge, right? Like a pop up tent?
Reply 28583 of 40040, by bofh.fromhell
It's obvious really, they are bulging with power.
Flat ones are, like batterys, depleted.
And if yours for some reason lack the bulge, badcaps has a handy list so you can get new ones:
http://www.badcaps.net/store/product_info.php … 7&products_id=9
What they dont mention tho is that any cap thats in the expansion slot area should be 15mm or less in height or it can foul any expansion cards.
I only know that cause I had a close call on my recent KG7 recap =)
(oh and incase someone finds this thread wondering about recaps, capacitors should obviously not be bulging 😉
Reply 28584 of 40040, by frudi
If you feel comfortable picking out the right capacitors yourself, you can get them quite a bit cheaper elsewhere. Don't get me wrong, I really like the bundles badcaps put together and it's a really nice convenient service they're offering with them. It's just if you can sort your way through something like digikey's catalog, you can get an equivalent selection of premium caps for about half the price of that bundle.
Reply 28585 of 40040, by blank001
Not exactly “today” but 2019 so far
2x Matrox G400 Max
2x ti4600 (someone dumped 30 cards for 30 a piece a little while ago)
3x promise s150 cards
Basically just buying good stuff when I see a big recycling company dumping on ebay below individual seller prices.
_: K6-III+ 450apz@550, P5A-B, 128Mb CL2, Voodoo 5500 AGP, MX300, AWE64 Gold 32mb, SC-55v2.0
_: Pentium III 1400 S, TUSL2-C, 512Mb CL2, Voodoo 5500 AGP, MX300
Reply 28587 of 40040, by bjwil1991
I can hear The Secret of Monkey Island music right now. I'm planning on setting up my 486 with the Yamaha DB50XG externally, the FB-01, and MT-32 on my Music Quest MPU401 clone card.
Reply 28588 of 40040, by stalk3r
Nice. I am also planning to set up a 386 with the original (now heavily yellowed) case that I had back in '94 and the MT-32. I do not have an MPU401 card though.
Reply 28589 of 40040, by peklop
Bump.
cyclone3d wrote:
An IPC MediaMagic Telemetry-32 soundcard/modem. […]
Supposed to have onboard wavetable as well. And looking at it, I bet those two large ROM chips confirms it. Just have to wait for it to get here and find drivers.
Original price was $399 I think. from what I could find. Maybe $299.
Edit: Found the drivers.
Here are a few links that mention this card:
https://books.google.com/books?id=eMKimy4DFaE … etry-32&f=false - This one actually shows a breakdown of what it supports.
https://books.google.com/books?id=PITtFPwTaWw … etry-32&f=false
https://www.atarimagazines.com/compute/issue1 … ultimedia_p.php
https://books.google.com/books?id=hzgEAAAAMBA … ry%2032&f=false
Interesting and rare DSP-based sound card. I found only one other owner:
OPTI 82C950
OPTi MAC32 chipset 82c950
http://bitsavers.trailing-edge.com/components … ochure_1994.pdf
How good is wave table and OPL3 emulation?
Reply 28593 of 40040, by mothergoose729
Tronix wrote:
New unused MDA/Hercules monitor ADI DM-14F: […]
P90509-191335.jpg P90509-191723.jpg P90509-191746.jpgP90509-193031.jpg P90509-193154.jpgP90509-200730.jpg
Man, there is just something about those amber screens 😊 .
Reply 28594 of 40040, by Dracolich
My 4MB Millennium II arrived today. What a sweet surprise - it includes the 4MB daughter board already attached. Not bad for < $2 😀
1.77 MiB
Reply 28595 of 40040, by dkarguth
Got the motherlode here...
Paid just over $400 for the entire lot.
IBM 5170 AT system with 5154 EGA monitor
IBM 5175 Professional Graphics Display (accompanied the IBM Professional Graphics Controller)
New in box IBM 5140 PC Convertible
IBM 5161 Expansion Unit
Texas Instruments Professional Computer (I am retrobriting it right now, so it's missing its case pieces in this picture
Compaq SLT docking station
Commodore 1084 Monitor
Texas Instruments Portable Professional Computer (color display model)
New In Box IBM AT disk drive
IBM 5153 CGA monitor
A crap ton of ISA and MCA cards
BY6kg9fl.jpg?1
Various IBM reference manuals and software
New in box IBM AT accessory kits with brand new model M keyboard
JxeJs2Cl.jpg?1
Texas Instruments Professional Computer Monitor
"And remember, this fix is only temporary, unless it works." -Red Green
Reply 28597 of 40040, by liqmat
Is this from that warehouse down in Texas? Most excellent finds. If you happen to come across any ITT system hardware, docs or disks I would be very interested in knowing about it. I archived the system disks for the ITT Xtra system already here, but would like to archive more ITT system software if possible. Looks like you're going to be busy for awhile.
Reply 28598 of 40040, by dkarguth
Yep! Computer Reset in Dallas. However, for anyone who wants to visit, it is rumored that it is going to shut down soon, so visit while you can.
Reply 28599 of 40040, by JonathonWyble
Man! That's a lot of equipment you got there. It was probably hard to get that stuff into your house 🤣
1998 Pentium II build
