Reply 28640 of 52812, by respect2759
Tomorrow I have these at home:
S3 Trio AGP
MSI MX4000 T128 AGP
Club 3D Radeon X1650 Pro
ASUS P5PE-VM LGA 775
+ an AsRock K7S41 socket 462 board with no photo from seller
This whole pack for 10 euros. Its 30km from me, but fortunately in the city where my gf works so it will be a 2in1, lunch together and a nice buy too 😎
    159.49 KiB
    100.93 KiB
    103.24 KiB
    167.7 KiB
Soyo 019R1 AM386DX 40MHz, 8Mb ram, 512Kb Trident 9000 Graphics
S26361-D756-X Intel i486DX 33MHz, 4Mb ram, 512Kb - 1Mb graphics on board
Reply 28641 of 52812, by Intel486dx33
dionb wrote:
Compared to plain styrofoam a woolen jumper woundn't even sound too bad. But why BS? The job of antistatic bags is to avoid any […]
luckybob wrote:
dionb wrote:
Actually newspaper is pretty good - its electrical characteristics are almost exactly the same as antistatic bags (i.e. it conducts very, very badly, but nonzero - so ESD-safe) and a few layers of it give better mechanical protection than a bag.
Compared to some of the other packaging I sometimes see, newspaper is one of my favorites.
I'm gonna call bs on this. But i'd wager is is better than plain styrofoam (not much of a competition there, bth)
Compared to plain styrofoam a woolen jumper woundn't even sound too bad. But why BS? The job of antistatic bags is to avoid any static charge buildup by (very slowly) leaking charge, and at the same time equalizing charges by conducting at least something. That's not rocket science, it's just a very high but very much not infinite resistance. Essentially antistatic bags are just reliably, reproducibly conducting through their material, while slowly leaking charge to ensure that whatever potential is present inside is the same as outside.
Newspaper isn't reliable or reproducible, but it essentially does the same. It beats any form of (non-conductive) plastic packaging, which unfortunately seems the norm.
I tell non-business shippers to use aluminum foil. 100% sure to short all pins together, thus preventing esd from penetrating the chip.
Assuming the aluminium foil doesn't tear. But yes, full conductivity - so essentially a faraday cage - is another approach that can work.
Edit:
Got my new toys working today
Puretek PT-2037, aka UMC UM85C418F-GP VLB board. Replaces my crappy UM85C408AF ISA VGA board in my UMC build. So far so good, it improves 3DBench scoers from 26.3 to 37.0. No FDD though, so I still need my multi-I/O card for that.
Nice, can you list all your UMC parts ? Or do you have a thread on this build ?
Reply 28643 of 52812, by Salient
Some other recent acquisitiions; a new in the box serial Artec 3-button mouse and an old xt-era PC joystick in very good condition.
Reply 28644 of 52812, by liqmat
melbar wrote:
I don't own any SB AWE 32, but now i have got this one. It has also the EMU8000... […]
What a strange little card. Is that a mini jack on the back?
Reply 28645 of 52812, by BloodyCactus
Its the Wavetable half of the AWE32. Its supposed to go alongside an SB16, like the GUS ACE.
Reply 28647 of 52812, by melbar
liqmat wrote:
I see. Never have seen that specific card before. Thanks.
CT1920 AWE32 Upgrade, Music volume
http://www.amoretro.de/2012/11/creative-sound … ard-ct1920.html
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 28648 of 52812, by Bige4u
Not in my possesion yet, but on the way... Aopen AX64 + Pentium3 1.0ghz/133 slot1 = wholesome goodness.
    406.44 KiB
    256.96 KiB
Pentium3 1400s/ Asus Tusl2-c / Kingston 512mb pc133 cl2 / WD 20gb 7200rpm / GeForce3 Ti-500 64mb / Sound Blaster Live! 5.1 SB0100 / 16x dvdrom / 3.5 Floppy / Enermax 420w / Win98se
Reply 28649 of 52812, by dionb
Not yet, but intend to do so when I have time (and when I've managed to get at least one of my UMC-based NICs to work under DOS...)
What I did have time for today was a quick pickup run to a neigbouring town for this:
I already had the SGI 1600SW monitor, but now I can hook it up to any PC thanks to the Multilink adapter. It converts either digital DVI or analog (via DVI connetor) to SGI's OpenLVDS for the 1600x1024 beauty.
And it was my lucky day - the seller wanted to dump more SGI stuff and had a Bigfoot Granite keyboard. It was in a bit of a bad state, with broken keystem on the '2' key, messed-up space bar and a few internal supports strapped off - but with a bit of superglue and a lot of patience I've gotten it working again - Alps SKCM Cream Damped goodness 😀
Reply 28650 of 52812, by respect2759
+2 Cards to my collection
    140.86 KiB
    152.59 KiB
Reply 28651 of 52812, by Dragon Caesar
This was a great week for me in terms of pickups. I obtained a extremely cool and extremely tall Pentium Pro system via eBay. It is a Shuttle HOT-613 single CPU w/ 128 megs of RAM equipped with two ST15150N hard drives that are now running MSDOS 6.22 as a RAID0 array. It originally came with 2 tape drives but I removed one and added a Teac 5.25. Worst case scenario, I can live inside the tower.
1.35 MiB
Saturday afternoon I decided to check out a estate sale and I'm glad I did. I found a tower lying on its side on the floor in the corner of a room with a VCR on top of it. I threw out a fair price with the assumption it would be a box of rocks and maybe one working thing and they accepted it.
1.24 MiB
When I took it home to take a look inside, I was pretty surprised with what was in there. In the expansion slots were a SoundBlaster 32 (CT3930), a VLB Diamond Stealth video card, and a VLB Acculogic sIDE multi IO card. Even more surprising to me was the CPU wasn't a Socket 3 processor but rather a NexGen P80 CPU with the NexGen FPU chipset accompanying it. I have never heard of NexGen before and I had initially assumed the badge on the front of the tower was a local computer shop.
1.52 MiB
1.92 MiB
Tested everything out, the NexGen tower needs a new battery and the cdrom drive tray is stuck but other than that everything is working great.
Reply 28652 of 52812, by dionb
You sir just struck gold, no platinum!
That NxVL isn't the FPU (if you'd found a NexGen board with socketed FPU you could probably give up your day job - but would have to hire a security detail too 😜 ) it's the motherboard chipset. This VLB version isn't as fast as the PCI one, but it is probably the most beautiful motherboard chipset out there.
Enjoy that board, and whatever you do, even if it is stone cold dead, DON'T throw it away. These things are rare and some very capable enthousiast may well be able to resurrect it.
Reply 28653 of 52812, by Intel486dx33
dionb wrote:
Not yet, but intend to do so when I have time (and when I've managed to get at least one of my UMC-based NICs to work under DOS. […]
I use to have a hacked Video card that could run Sun Microsystems displays on a Windows PC.
I think it was an S3 Savage 4. I think it was AGP and it had a green heat sink.
“Mirage Illusionist 3D AGP”
Reply 28654 of 52812, by Dragon Caesar
Good catch, thank you! Just edited my post to reflect that. Will be enjoying the board for sure, even more once I replace the battery so I don't have to reconfigure everything every time it boots.
Reply 28655 of 52812, by Intel486dx33
I would like to read up on this computer if you would like to place a review in “System” forum category.
Take some nice photos and benchmarks. System specs and stuff. It’s a really neat looking computer.
Envious for sure.
Reply 28656 of 52812, by dionb
I think it was an Nvidia Riva TNT2. I think it was AGP and it had a green heat sink.
See that other monitor on my photo? That's a Sun LSA800 and it works just fine with the same - VGA - output I used for the 1600SW+Multilink 😉
Most later Sun monitors were simple multisync devices that could run on unmodified PC hardware (at least, if you had DE15->13W3 cables/adapters). You probably had an earlier single-frequency monitor. They would need some driver hacking to work under windows, that's most likely what you did.
Reply 28657 of 52812, by Intel486dx33
This card for Sun / SGI displays. Back in the early 2000’s there where allot of SUN and SGI displays for sale on eBay but they sold for dirt cheap because everyone was using Windows computers so no one want to buy these proprietary displays. So someone hacked this card to work.
Reply 28658 of 52812, by appiah4
dionb wrote:
Edit: Got my new toys working today https://tweakers.net/ext/f/dour551yetUAUFoJOK9bmXg8/full.jpg […]
Edit:
Ohh, nice! Can the U5S CPU do 40MHz FSB?
Reply 28659 of 52812, by dionb
Not tested (yet). Will put on to-do list though 😀
Might take a while as I'm getting guests over on Thursday, then heading with them to a reunion lasting all weekend. Until Thursday I'm tidying up to make sure they have somewhere to sleep that doesn't have PCBs or - worse - screws sticking out at them, then away till Monday, and probably hung over until the weekend after. Spent 4h this evening getting the first bit done, not even had time to seriously play with my SGI screen yet 😵
