Reply 29360 of 40042, by Salient
Still in transit;
1) The Blasterboard from one of our fellow Vogoners (maybe I should type that as Vogon'ers)
2) Yamaha DB51XG daughterboard (finally found one for a 'decent' price)
Reply 29361 of 40042, by pan069
appiah4 wrote:
I had never intended to collect any 286/386 era hardware but lately I've just been coming across these things and for good price […]
I had never intended to collect any 286/386 era hardware but lately I've just been coming across these things and for good prices, usually below $20 per motherboard. This one here was on sale for $15 only. I grabbed it. Untested and has some battery damage but it should work I would think.
Has an AMD 286-16 on it and a fixed amount of ram. I wonder how fast that is compared to the current 386SX-25 I am working on right now.. I can't wait to put this in a suitable case alongside my Adlib clone and MusicQuest clone to play some sweet Sierra games 😀
Only question is, what is that unpopulated IC socket to the north of the CPU? Coprocessor? Hmm..
I have a number of 286 Headland based boards, looks like the FPU socket. Interesting to see multi IO on the board itself. You don't see that to often on 286 boards.
Hopefully that battery didn't do to much damage. Love to see a other photo of it once you've got it cleaned up!
Reply 29362 of 40042, by bjwil1991
Bought a Socket 5 system built by a fellow Vogon'er and is in transit via FedEx for $45 shipped and the GameBoy DMG-01 bundle I ordered is in transit... via FedEx (was advertised as USPS for shipping on shopgoodwill.com) for over $100 (yes, I know that's a bit pricey, but, it has a few accessories, like the 4-player adapter) and they need cleaning severely, which I'll be cleaning them before I use them (gloves, Isopropyl alcohol, and lots of sponges).
Reply 29363 of 40042, by appiah4
Yeah looks like an FPU socket indeed. Doing some research; seems a 286-16 with Headland chipset was a fairly common build in the early 386 years, kind of like the 386DX-40 during the early 486 years. Kind of musing about replacing my 386SX-25 MS-DOS 5.0 system with this now. Worth it? Good idea? I don't know.. Sounds like downgrading from a slow 386SX to a fast 286 has absolutely no benefits..
Reply 29364 of 40042, by yawetaG
These two are waiting for transit:
113.63 KiB
External SCSI ZIP 250 drive
150.5 KiB
External USB ZIP 250 drive/PCMCIA card adapter/SmartMedia card reader, usable as stand-alone device for transferring photos and video from PCMCIA CF cards adapters and SmartMedia cards to ZIP disks and to/from cameras and S-VHS video recorders , or as an PC/Mac drive (I wonder what the functionality of the PCMCIA card adapter will be in that case...).
Both used and mostly complete. The combo drive was sold as untested, so we'll see.
Reply 29365 of 40042, by pan069
Well, a 386SX at 16mhz can still be faster than a 286 at 16mhz since the 386SX will still be a 32 bit CPU, i.e. they will be similar in speed but the 386SX will be more versatile in that it will be able to run software that requires a 32bit CPU (e.g. Windows 3.11). But yeah, the 16 bit bus is probably going to be the bottleneck. 😀
Reply 29366 of 40042, by Deksor
Well that's not what benchmarks seem to tell. It seems like the 286 is closer to a 386DX in terms of raw performance, as long as it runs a compatible software. But yeah the 386SX is way more versatile.
alternative
Reply 29367 of 40042, by wiretap
Picked up a new old stock Nvidia 7800GTX ($10, Dell logo on the fan shroud) for my Elitegroup KN1 Extreme / AMD FX60 build.
Circuit Board Repair Manuals
My Project List
Reply 29368 of 40042, by pan069
What benchmarks are those?
Reply 29369 of 40042, by Bige4u
First a DELL version, now a Leadtek Winfast version with all the goodies(vga/dvi/tv).... GeForce2 Ultra 64mb AGP4x
Pentium 200/ Biostar M5ATA / 2 x 32mb EDO / Seagate 3.2gb 5400rpm / Diamond Stealth3D 2000 4mb / SB16 CT2980 / 40x cdrom / 3.5'' Floppy / Solar Power 250w / Win95c
Reply 29370 of 40042, by bjwil1991
Cool card, man. Word of caution: please oil the fan before powering it on and using the card.
Reply 29371 of 40042, by wiretap
That fan can just be replaced with a new one too. They are still made in that size/style. To keep the WinFast sticker, a new one can be printed with the same size and font on any InkJet or LaserJet printer with sticker paper. 😀
Edit.. here's the ones I use: Millennium Fan MFAN-1024-D 12VDC 0.06A 45mm x 45mm x10mm OL0379
Example: https://www.ebay.com/itm/Millennium-Fan-MFAN- … GMAAOSwYhtc7qWe
My Project List
Reply 29372 of 40042, by bjwil1991
I should get a new one for my GeForce4 Ti4400.
Reply 29373 of 40042, by Bige4u
Thanks... but the first thing i usually do is run my videocards for a minute or two in the machine to see and hear the condition of the fan, reoil it if necessary, then i'll pull off the heatsink, clean off the old and reaply fresh thermal paste on the gpu, i always like to use artic silver ceramique2, its good stuff.
Reply 29374 of 40042, by bjwil1991
I use the Arctic Silver 5 compound for the northbridge, GPU, and CPU heatsinks and it does a lot better than the cheap thermal compound that computer companies use. I used it on my old Xbox 360 before the GPU failed and it ran a lot cooler than before and the fans were louder (might've installed the heatsinks backwards) and on my Xbox Original 1.6b that still runs without any issues.
Reply 29375 of 40042, by MMaximus
There are several threads on Vogons about this, but you can check this one for starters. In my experience if we're strictly speaking about games, a good 286-12 with 0 wait states will keep up with a 386sx16. And a 286-16 will usually outperform it.
Reply 29376 of 40042, by Grzyb
Yes, it's a well-known fact.
386SX has a paging translation unit, ie. additional level of logic elements between the CPU core and memory, which inevitably introduces some delay.
Reply 29379 of 40042, by wiretap
Intel486dx33 wrote:
Awww, Nice ! Hard to find. I want silver one. Check out mine. Ultimate Audio / Gaming build - Terratec/SB Audigy2zs […]
Awww, Nice !
Check out mine.
Nice, it looks awesome in black. 😎
This one that I just ordered, it was only me and 1 other bidder for the past 4 listings of it -- nothing went higher than $20, but the seller had a reserve price (unknown). He finally gave in at this last auction listing and gave me a Second Chance Offer. 🤣
I think I'll put a DMX6fire in mine too. I have one waiting to be installed in a silver case.
My Project List
