Reply 29380 of 40042, by bjwil1991
Intel486dx33 wrote:
Awww, Nice ! Hard to find. I want silver one. Check out mine. Ultimate Audio / Gaming build - Terratec/SB Audigy2zs […]
Awww, Nice !
Check out mine.
I have that exact Pentium 4 board. Forgot RAMBUS requires all 4 slots to be populated in order to use it or 2 slots with RAM and the other 2 with termination RAM. Much like SCSI as well. Termination adapters are required in order for a CD-ROM drive or hard drive to get detected.
Reply 29381 of 40042, by Bige4u
I really dig those cases that have a removable motherboard tray... makes system building so much easier.
Pentium 200/ Biostar M5ATA / 2 x 32mb EDO / Seagate 3.2gb 5400rpm / Diamond Stealth3D 2000 4mb / SB16 CT2980 / 40x cdrom / 3.5'' Floppy / Solar Power 250w / Win95c
Reply 29382 of 40042, by mothergoose729
I scored a great deal on a Voodoo 3 PCI today 😁. It was still maybe the most I have paid for a retro part, but much less than the going rate for PCI voodoo cards these days.
I have a socket 7 build and a socket 478 machine. My hope is that I can get the voodoo card to work for glide games and use my FX card for openGL and directX. If they refuse to play nice together, then I'll put it in my dos machine instead.
Reply 29383 of 40042, by bjwil1991
Don't forget to add a fan to that thing. Learnt that the hard way with my first VooDoo3 2000 PCI card. My V3 3000 PCI card has a fan on it (added one myself) and it still works.
Reply 29384 of 40042, by mothergoose729
Yeah that is definitely part of the plan. It would make for one expensive coaster.
Reply 29385 of 40042, by luckybob
Finally found an IBM 365 for a half-way reasonable price.
ebay seller images:
I'll know in 7-17 days if the door survives the trip around the world.
Reply 29386 of 40042, by bjwil1991
Hope it survives, man.
Reply 29387 of 40042, by arncht
My 3000 does not have a fan, and it still works 😀
Bought this retro hardware
Reply 29388 of 40042, by xjas
Yeah, I don't notice my V3 2000 getting hot to the touch, just a bit warm. I even ran it at 75MHz AGP for a while with no issues. It has a bigger heat sink than the one pictured though.
Reply 29389 of 40042, by kixs
I saw this and made him an offer as the price was too much for me... especially in unknown state. I hope it survives the trip as the case is in nice condition and it actually works when you put in the cpu(s).
Reply 29390 of 40042, by luckybob
@kixs
Yea, I know. total gamble. but for some *censored* reason people want 5-6 hundred dollars for the damn things. I got lucky. I had a small windfall of money, and I just had to take it.
Reply 29391 of 40042, by arncht
The last really high end s3 chipset, the vision968 on a diamond card with the excellent ti dac (same on the famous matrox millennium).
benchmarks here:
Fastest video card for DOS, Socket 3 VLB / Socket 5 / Socket 7 / Slot 1 FPS comparison
possible config here:
Re: Socket 5 @ 1995.05 - Pentium 120, ARK Logic ARK2000PV, Sound Blaster AWE32, Gravis Ultrasound
    458.6 KiB
Reply 29392 of 40042, by Anders-
luckybob wrote:
Finally found an IBM 365 for a half-way reasonable price. […]
ebay seller images:
You got the dual ppro one, nice! Really like their way of thinking with stacking pci and isa slots together in order to optimize usage.
Reply 29393 of 40042, by imi
retro workstation build incoming 😀
335.49 KiB
also my current way of trying to acquire more retro hardware isn't terribly efficient, I particularly dislike that the scrappers remove all metal parts, most cards missing their slot covers and some of the motherboards that otherwise look fine sometimes have damage on the chipset from ripping the heatsinks off, and then there's of course just a bunch of parts just being outright broken or damaged, but still better than nothing I guess.
385.95 KiB
Reply 29395 of 40042, by canthearu
arncht wrote:
The last really high end s3 chipset, the vision968 on a diamond card with the excellent ti dac (same on the famous matrox millen […]
benchmarks here:
I got one of those in the AMD 5x86-133 I built. It is quite a good card for that machine.
Reply 29396 of 40042, by gdjacobs
Tyan Tiger MP/MPX?
Reply 29397 of 40042, by arncht
benchmarks here:
The original price was $389, not too many people paired with a cheap cpu 😀 maybe in 96 was a little bit outdated, but the trio64v+ was always muchmuch cheaper.
Reply 29399 of 40042, by x0zm_
Bought a new case for my 233MMX project. I'll be using its current case for something else because it has some sentimental value to me, but it just didn't turn out to be the fit I needed for this build.
My purchase was an AOpen H700A. It may not be 100% time period correct, but it was new old stock and will do exactly as I need. Seems to be from around 2002, so not too terrible. Seller pics attached.
The reason from changing from my current case is quite simple - this case has the four additional hard drive bays above the PSU, which is exactly what I needed for the build having a total of six HDDs.
It will still require some minor modifications to make it how I want it and to remove some of the "new" factor from it. Plans include swapping out the clippable 5.25" covers with regular ones from that big box of covers I found awhile back. Replacing the front USB area with some smoked acrylic and a MHz display which I have laying around and chopping up some of my blank ATX IO covers to support AT keyboard and have holes for Serial and Parallel ports.
Having a brand new PSU in there is a bonus too, but I'll find another home for that.
Also having so many 80mm fan locations will keep everything nice and cool - and a cool system is a happy and long lasting system! Looking at an archive of the AOpen site seems to indicate around seven fan slots. Absolutely wonderful.
Looking forward to it. 😀
