Reply 29680 of 40043, by arncht
appiah4 wrote:
Got me a new AT case because those are starting to get more and more rare.. […]
It was sold as an OEM computer in the early nineties by the same company I bought my first PC (Intel 486 DX33 4MB VLB) from, and it's the Mid-Tower doorless model of the case I had which was a Full-Tower with a front door.
I was going to build my 486 with a NOS AT case I had around, but this changes everything. Needless to say, a 486 system will have to be built in this and moved to storage.
I guess I will just do a PCI/VLB 486 DX4-100 build with a Voodoo 1 running Windows 95/Warp3 dual boot in the NOS case and use it as a daily driver because why not..
I also got another AWE64 for just $5.
The dx4 is very slow for a voodoo.
Bought this retro hardware
Reply 29681 of 40043, by imi
Predator99 wrote:
For the 10kg, I didnt see most of the cards that were inside on the sellers photo and was rather surprised about the big box. Think Imi also bid on this? 😉
I ask the seller to add the slot brackets. I think he added all he has (50 kg cards in total, will se if I get another lot).
well... those alone are going to come in very handy, sorry about the butchered cards 🙁
I don't think I've even found that one ^^
we should coordinate our bidding :p
Reply 29682 of 40043, by yawetaG
Just received this lovely box:
134.17 KiB
Containing a MU128:
127.51 KiB
Containing a PLG-100VL board (the exact board I once found cheap on Ebay and then forgot to bid on):
122.79 KiB
Included were the manuals, PC cable, original PSU, and inner box material. The latter was a good thing because the company I used to buy it in Japan and ship it thought this was all that was required to send it over half the world:
130.21 KiB
They didn't even bother to tape shut the box, just put a triple layer of bubble wrap around it. WTF? 😒 It could have ended in disaster.
Edit: Tested, and everything works. Also has firmware version 2.0, so it's GM2-compatible. 😀
Reply 29683 of 40043, by imi
I have no idea why somebody would even sell this... but oh well I used the opportunity ^^
181.03 KiB
also got these, the speaker case is going to need some repairs, and a free CRT 😀
125.66 KiB
68.31 KiB
Reply 29684 of 40043, by bjwil1991
Went to a computer shop that sells items from retro to modern and repairs systems from the past to the present and bought a ThinkPad docking station, the power adapter, and the external floppy drive for my ThinkPad R40 as I needed a floppy drive and a docking station for that laptop anyway for $40. Not a bad price for the items. Could've bought the Audigy 2 ZS and Radeon AGP card, but, I'll get them later on and there was a Pentium II board and they also sell those Slot 1 CPUs as well (will buy the board, video card, sound card, and the CPU someday and build a sleeper system).
Also went to a local video game store and bought a genuine SNES power adapter for a good price of $14.95
Reply 29685 of 40043, by Vegge
Got some free stuff today 😀
Number Nine graphics accelerator för ISA( bent like a banana, but I hope it works), Tseng ET4000AX and a Nokia branded 8-bit ISA vga card.
1.51 MiB
MFM-controller, memorycard, SCSI-controller and two random 72pin sticks.
1.38 MiB
Six old IDE drives and an old SCSI drive.
1.1 MiB
NEC Multispin with caddy for SCSI
1006.82 KiB
I didn't bother with pictures on the other stuff; an external casing for optical SCSI, two floppydrives, 50x IDE cdrom, some random cables and other junk.
The stuff needs some cleaning and testing, but free is free 😎
Reply 29688 of 40043, by appiah4
Got these two for not much.. My second SUPER33, I really want a SUPER40 🙁
Perhaps but it's just lying about and will allow me to play Quake on a DX4-100 so why not?
Reply 29689 of 40043, by respect2759
Just call the phone number on the sticker and order one 😊
Soyo 019R1 AM386DX 40MHz, 8Mb ram, 512Kb Trident 9000 Graphics
S26361-D756-X Intel i486DX 33MHz, 4Mb ram, 512Kb - 1Mb graphics on board
Reply 29690 of 40043, by derSammler
It won't. It will look much better, but not run any faster. The frame rate of quake is limited by the 486's slow FPU (or more correct: the Pentium-optimized way the FPU is used). I have such a setup - well, it's using a POD now, but was a DX4 before - and while it can *run* Quake, it's barely playable on a DX4. The Voodoo won't change that.
Reply 29691 of 40043, by appiah4
Isn't Quake's FPU dependence related to its software renderer anyway?
Reply 29692 of 40043, by derSammler
No. Keep in mind that the 3dfx cards only do the last stage of the rendering, unlike modern 3d graphics cards. All the geometry calculations are still done by the CPU, and so the FPU is still used. If I'm not mistaken, having an FPU is even a requirement for 3dfx, since Glide heavily relies on it.
When I installed a Voodoo1 in my DX4 and tried Quake for the first time in 3dfx mode, it was even running slower than with software-based rendering, because it started in a higher resolution, causing more CPU-load.
Reply 29693 of 40043, by Intel486dx33
Vegge wrote:
Got some free stuff today :) […]
That “Number Nine” ISA is nice.
Reply 29694 of 40043, by appiah4
Ahh, I see. I'll just stick with a fast PCI card then; I have a few options (Trio64, ARK1000PV, MX86200FC or Millennium).
Reply 29695 of 40043, by Wolfus
I will gladly accept Voodoo1 as a gift 😉
Reply 29697 of 40043, by appiah4
derSammler wrote:
If the mainboard supports it, you can install an AMD X5-133 overclocked to 160 MHz. This will give you about 16 fps in Quake with the Voodoo at 512x384 resolution.
I don't have any 5x86 or X5 CPUs; DX4-100 is the fastest I can go with. Regardless, if I wanted a Pseudo-Pentium I would just build a K5 system anyway 😀
Reply 29699 of 40043, by appiah4
arncht wrote:
typically paired the v1 with mmx / early p2.
My friends used the Voodoo with Late Pentium or MMX CPUs. At the time I was stuck with software mode Quake with a P-100 (or 120/133, I can't remember for sure). I went straight to a Voodoo 2 with a PII-300.
