Reply 30020 of 40045, by MMaximus
canthearu wrote:
Quantum fireball drives for the most part are pretty terrible for retro builds.
I have half a dozen in near perfect work condition, but I can't stand having them run for more than an hour with their high pitched bearing whine. I use newer Seagate/WD drives with fluid bearings in most of the retro PCs,
That's exactly what I was thinking as I'm currently going through a lot of old hard disks taken from late '90s / early '00s machines. Were ALL the hard disks from this era dreadful? 😵 Not even speaking of reliability: Fujitsu, Quantum, Maxtor, they all sound pretty bad, with IBM being the worst offender. From that lot, only a Caviar 80Gb from WD seem to not have this annoying high-pitched whine...
Reply 30022 of 40045, by Bige4u
Nice, clean and what a thing of beauty.
Abit Siluro ti4600 128mb
Pentium 200/ Biostar M5ATA / 2 x 32mb EDO / Seagate 3.2gb 5400rpm / Diamond Stealth3D 2000 4mb / SB16 CT2980 / 40x cdrom / 3.5'' Floppy / Solar Power 250w / Win95c
Reply 30025 of 40045, by respect2759
Robert B wrote:
Flea market result of the day! :D 2 EUROS for this beauty! NO BRAINER! Untested though ... […]
Flea market result of the day! 😁 2 EUROS for this beauty! NO BRAINER! Untested though ...
ELSA Erazor X -A32 nVidia GeForce 256 SDR 32MB AGP
I like uncommon card designs
Soyo 019R1 AM386DX 40MHz, 8Mb ram, 512Kb Trident 9000 Graphics
S26361-D756-X Intel i486DX 33MHz, 4Mb ram, 512Kb - 1Mb graphics on board
Reply 30026 of 40045, by CrFr
"New" mouse. Color matches better with the rest of the system than the previous bright white Intellimouse 1.3A. Overall in great condition, but it is missing one of the feet.
594.35 KiB
Reply 30027 of 40045, by canthearu
derSammler wrote:
That's because of drying-out ball bearings. None of these drives were made to be used 20 or more years later.
It's not only that, but most of these drives were not that quiet even with newish.
When new, they may not have quite the same high pitched harmonics, but they still were not at all quiet.
Reply 30028 of 40045, by Caluser2000
They are terrible mice though in use and construction. The MS mice were much better quality.
Reply 30029 of 40045, by CrFr
I don't even care 😀 It's more about the looks. If I wanted a good mouse, I would just plug in some Intellimouse Optical instead of these crappy ball mice. But then it wouldn't look nice with these other beige devices I have. Maybe some day, when I have too much time in my hands, I will implant an optical mouse into this shell.
But I wouldn't call this terrible. Moves quite nicely. Buttons are bit too stiff. Also ergonomically this is almost as bad as the first PS/2 mouse IBM made. Build quality seems just fine to me.
Reply 30031 of 40045, by Deksor
So yesterday I was in Lille's flea market. Came back with a lot of good stuff 😁
First items : A Compaq Armada E500 With a celeron 550MHz, 5GB hdd and 64MB of RAM. Works well, the battery works too (but only for 15 mins). I merged it with parts from an other armada E500 I had to end up with a 850MHz P3 and a bigger screen. Only issue now is that the 850MHz PIII mobo has a problem with audio (I've made a post here : Compaq Armada E500 noisy speakers).
The other item is a Lifetec LT9888 which has a Pentium II 233MHz, 32MB of RAM and 3GB hdd. A madman installed Windows 2000 SP4 on a 1GB partition. The poor thing had no more ram left and no more swap left ... So I removed 2K from there x).
This is a nice laptop as well, but I've seen a crack on a hinge that wasn't there before, I fear that the plastic have become super brittle ...
Anyways, let's continue :
Next items :
704.1 KiB
mmmh floppy disks 😁. There must be a thousand of them in there. I couldn't take it home yet though, I'll see the seller later to bring that home. I've taken some disks home though. I took DR-DOS 6.0 disks that were in there to my home to test them and a bunch of 3.5" disks.
Unfortunately the DR DOS disks were stored outside of their protective paper, so the disks got a bit nasty and they need cleaning to be read ... on the other hand, disks that were stored properly survived quite well. Whew I thought this was going to be a huge disappointment, but thankfully only disks that were left unprotected got bad it seems.
Next item:
1.8 MiB
an amstrad CPC 6128 ! I've tested it, and it works 😁
... well for the most part at least. This is the FDD's belt. Thankfully they can be found easily.
634.33 KiB
Next item :
1.57 MiB
An amstrad PCW8256 !
it's just the computer/monitor though, I don't have the keyboard nor the stand for it, but that's still pretty cool !
Also, it has the same failure as the CPC ... oh well that's not a big deal. But that means I can't test it right now (it needs a floppy to boot)
I also found a boxed version of Heroes of Might and magic II with two CDs and some mac related books.
alternative
Reply 30032 of 40045, by McBierle
Got a bit sidetracked. It was sold as defective. Actually the power input had to be changed and one solderpad was broken.
469.08 KiB
Reply 30033 of 40045, by PcBytes
A friend gave me this board from his girlfriend's old PC for the price of 2 beers.
Soyo SY-6BA+IV, P3 500MHz Katmai, originally came with 128MB of RAM, added a few more sticks to make 384MB.
Reply 30034 of 40045, by CelGen
oeuvre wrote:
I'm not sure exactly if it is a voice modem but the FM synth is pretty good.
It is.
I have multiple Packard Bells and these are the stock combo cards for models that supported data/fax/voice options in Windows and Navigator. The headers for TV and FM tuner options are dead giveaways.
Reply 30035 of 40045, by dionb
CelGen wrote:
It is.
Yep. With pretty standard Rockwell modem hardware too. Once - must have been around 2000/2001 - I got an old Packard Bell P60 system and one of these Aztech modem/sound cards (also PB, but definitely newer than the P60), stuck it in and installed Linux. It was my second ever attempt at running Linux and unlike the previous time (Mandrake on in i810 system long before either i810 or AC'97 codecs were supported by Linux) it just worked first time 😜
Reply 30036 of 40045, by Merovign
I don't think I've seen a floppy disk "in the wild" for a decade. Just super pricey and dicey eBay lots. I think everyone locally just throws them in the trash.
*Too* *many* *things*!
Reply 30037 of 40045, by Deksor
Well appart from few boxes of 10 3.5" disks here and there, sometimes a box of like 50 disks, I never found that many disks in a flea market ! And I've never found 5.25 disks in a flea market period, so this is super cool ^^
alternative
Reply 30038 of 40045, by wirerogue
that's alot of ide.
