Reply 30040 of 40045, by PcBytes
wirerogue wrote:
PcBytes wrote:
A friend gave me this board from his girlfriend's old PC for the price of 2 beers.
Soyo SY-6BA+IV, P3 500MHz Katmai, originally came with 128MB of RAM, added a few more sticks to make 384MB.
that's alot of ide.
I know, that's because of the HPT366 RAID controller. I theoretically can stick about 7 HDDs in there and make a server 🤣. 4 in RAID, and 3 through the usual Intel chipset IDE interface
Reply 30041 of 40045, by varrol
1.48 MiB
1.38 MiB
Sorry for picture quality - but you know what it is 😀 Very cheap, were looking not very promising from pictures, but after cleaning up, and fixing a broken front on the bigger one, they look pretty fine.
AOpen AX6B+ | P3 1G | 1GB ECC REG | FX5200 | CT4500
AOpen AX59pro | K6-2 450M | 256MB | Rage 128
Asus CUBX-E | P3 1G | 512MB | GF4 TI4200 | YMF719E-S
Asus P3B-F | P3 933M | 384MB | Radeon 9200 | CT4520
Asus P5A | P55C 200M | 256MB | Riva TNT | CT3600
Reply 30042 of 40045, by Vynix
Ooh the second one... It's a Chieftec Dragon, isn't it? But the first one, I have no idea 😦
Reply 30043 of 40045, by MMaximus
canthearu wrote:
derSammler wrote:
That's because of drying-out ball bearings. None of these drives were made to be used 20 or more years later.
It's not only that, but most of these drives were not that quiet even with newish.
When new, they may not have quite the same high pitched harmonics, but they still were not at all quiet.
<OT> That's what I remember as well from the Athlon / PII / PIII era. Hard drives were very loud and not in a nice way. Combined with loud PSU and CPU fans, it made you want to wear earplugs at times. That was before they started marketing cases geared towards noise insulation (i.e. Antec Sonata). </OT>
Reply 30044 of 40045, by imi
I used a 38mm thicc vantec tornado 80mm fan on a swiftech MCX462 on my athlon XP as my daily driver... PCs were supposed to be loud back then ^^
I've been looking everywhere for that swiftech, I remember specifically keeping it but I can't seem to find it 😒
Reply 30045 of 40045, by imi
oooooh it arrived... look what I found 😀 something special to add to my growing drive-collection
101.6 KiB
103.82 KiB
manufactured 1988 ...it looks pristine 😀
...unfortnately I don't think I have any card with LMSI interface to try it out... also, and excuse my ignorance, how do you put a something in this drive, does it use special caddies or anything like that? ^^ I can barely find info on how to use it... it is a cd-rom drive right, does it use special media? 😕
Reply 30046 of 40045, by derSammler
This is a very nice one, had an internal version of the drive in 1997 (lost it back then, sadly). It uses a very special caddy. You insert the disc into the caddy, the caddy into the drive until you hear a click, and finally you remove the caddy again. The disc stays in the drive then. Inserting the empty caddy will give you the disc back. If you did not get the caddy with it, it's only a nice-looking doorstop, unfortunately.
Reply 30047 of 40045, by imi
thanks, I figured something like that, do you happen to have an image for such a caddy anywhere, what they look like?
I can find several pictures of drives but not of the caddy used.
if all else fails I could try to make one myself, I do have a 3D printer.
Reply 30050 of 40045, by imi
thank you!
I totally feel like I've seen that before somewhere, in a video maybe, but not as a caddy but just as a CD case 😕
edit:
🤣 thank you so much, I just hopped on ebay and searched for "CD case" and found an auction right there immediately with 8 minutes left, 12 of them for 5€
Reply 30051 of 40045, by derSammler
Well, this one is a CD case. But the caddy back then was almost the same. Maybe some company re-used the patent.
Reply 30052 of 40045, by imi
oh yeah, well I'll try it anyways 😀
and if it doesn't work, I'll have a bunch of nice cd cases ^^
edit:
ok I seem to now have found a picture of an actual caddy, that does look quite different though:
http://www.freetimeweb.nl/home/picture/sub/el … i_180_front.jpg
it looks like something I could make though if I had the exact measurements.
Reply 30053 of 40045, by yawetaG
imi wrote:
oh yeah, well I'll try it anyways :) […]
edit:
Errrr...that's for the pictured Philips CDi players. There's nothing to suggest it is the model of caddy that is needed for your drive.
Reply 30054 of 40045, by derSammler
imi wrote:
edit:
Yes, that's the exact caddy. Like I wrote, the blue parts inside the caddy that I've posted are different. Obviously, since the original caddy has that part to stay in the drive. You could try to 3d-print that "cradle" and use the outer shell from the CD case.
Reply 30055 of 40045, by imi
if you look at the plastic "door" piece in the drive it looks exactly the same, and also has those same "notches" on one side of the drive and caddy, and seeing how LMSI units are basically philips drives it's safe to assume imho it is the correct one.
Reply 30056 of 40045, by Deksor
canthearu wrote:
Deksor wrote:
So yesterday I was in Lille's flea market. Came back with a lot of good stuff 😁
Your flea markets make me green with envy!
Well this one is internationally known because it is so big (or at least I think it is because I heared many foreign languages when I was walking around). People from Spain, Netherlands, England, Germany .... And many more !
Anyways I, I'm quite happy with all my finds, now I have to get the floppy disks lot 😀
alternative
Reply 30057 of 40045, by Caluser2000
Bought this today. An EeeBox E202. 2GHz Atom N270 wih 1gig of ram and 80gig of storage. Always wanted a mini pc. At $40 it was a good deal.. Comes with XP Home. Didn't have an antenna but have spare pci wifi cards I take one off of and I need to get a DVI to VGA converter which I'm just ordering. Comes with 2 series 2 usb front and 2 at the back 0f It. 1 RJ45 connector at back and SD card slot up front.
It will suite my modest needs just fine. Needed something small and intrusive in my computer hobby area for quick internet searching and odd download. It'llmost likely set under the 10/100 4 port switch. Windows XP will go. And something more modern will be installed. Probably some form of Linux, Devuan maybe. All the hardware is 2008 era and pretty damn standard. It has a restore partition in case I want to revert it back to original config. If I can I'll upgrade the ram to at least 2gigs as that is a sweet spot for using XFCE4. If needed I have an external usb DVD writer and external 3.5" floppy drive.
1.38 MiB
Reply 30058 of 40045, by PcBytes
2MHz? Come on, a XT machine is faster than that 🤣
Reply 30059 of 40045, by Caluser2000
Cheeky lit'l monkey. Corrected 😉
