Reply 31560 of 52813, by brostenen
liqmat wrote:
derSammler wrote:
liqmat wrote:
Great product.
The V2 is actually quite a big step backwards, buggy and with features removed. Get the V1 instead if you can.
That's too bad. I installed the V1 on a revision 4.x board and it worked like a charm.
I see two issues with it.
One is that I can not update the firmware without a lockup on the V2 that I already have in my Amiga600. And this one that I just recieved, locks up when I try and update the firmware in my Amiga500 Revision 6a that are my 500-Desktop. The only way I can update, or bring it back from a lockup. Is to install it in my Amiga500 Revision 5 machine, and run the Resque disk.
The other is issue is:
If I use a low grade monitor, then it will make some slight ghosting effects in Workbench or other pieces of software, that have white or light grey background. I see nothing in most games.
As for the bricking/locking of the scandoubler. Then I suspect that it is related to the Agnus in some form. Or it is related to over 512k of Chipram. As far as I understand by snooping around on Individual Computers forum, then it is shipped as an OCS devinise setup. There is a setting in the Tool that one can download, in wich it can be kicked into ECS mode. So my guess, is that it might be related to the Agnus. On the other hand. It is running well as of now, and I can not begin experimenting before after X-Mas.
Reply 31561 of 52813, by imi
HanJammer wrote:
This dude with original PSU and USB midi interface... […]
Needs some minor cleaning...
Make my wish come true
All I want for Christmas is em-tee-thirty-two! ;D
I think I see double 🤣
Reply 31562 of 52813, by pentiumspeed
Been long time last time I had a Compaq LTE 386s/20 (discontinued model in summer 1993) from reseller for $1,000, this was my first notebook computer for college.
Just bought a Compaq LTE Lite/25 to work on, waiting for computer to come to me, my xmas present. I know I need to get software for it to set it up (software configuration to set CMOS settings and few utilties for power management.) Do you know where to get these? These came in really big packaging and is usually came with few 1.44" floppy disks with each LTE series notebook.
Cheers,
Great Northern aka Canada.
Reply 31563 of 52813, by Windows9566
brostenen wrote:
derSammler wrote:
liqmat wrote:
Great product.
That's the thing. The V1 have been sold out for the last two years. And it will not be produced anymore, because some of the components can not be sourced. And if I find a V1, then it is a used without varanty and extremely expansive. Nearly twice the price sometimes.
I haven't had any issue with my voodoo 2 on Windows 95 or Windows 98
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
Reply 31564 of 52813, by liqmat
This is actually about an Amiga product called the Indivision ECS V2 and the first revision was the V1.
Reply 31565 of 52813, by PC Hoarder Patrol
Been looking for one of these for a while but online prices tended to put me off, so am very lucky to have found one on local classifieds more in my price bracket; an ASUS P2B-DS in excellent condition (Rubycon + other caps all look fine). It's a D02 pcb with uprated VRMs but not the later clockgen chip. Already tested with a pair of sloketed coppermine 850MHz cpus - happy days 😀
1.7 MiB
Reply 31566 of 52813, by MCGA
I bought Sid Meyer's Railroad Tycoon complete in box and an Apple IIgs case.
I'm going to put a Mac Mini into the Apple case. I can uses the extra space to to improve the cooling -- which is horrible with Apple's hardware in general -- while also improving the looks.
I hope this case shows up in the same condition as pictured and nothing is broken.
    424.9 KiB
Reply 31567 of 52813, by JimWest
CharlieFoxtrot wrote:
Second Ultra Sparc II 450MHz processor card for my Ultra 60. Processor card is without the plastic shroud in the picture. It is quite a beast compared to for example Slot 1 processors of the same era.
I've never seen anything like that. Looks pretty cool. 😎
Reply 31568 of 52813, by sf78
Horun wrote:
$8 locally on the speakers.
Interesting to see people still enjoy using those. Meanwhile I'm at work throwing things like these to trash: 😒
135.89 KiB
Reply 31569 of 52813, by Cyrix200+
Oh no would have loved to have those! I had the same ones for years. Target was (is?) a big brand here.
EDI: this is not meant as a negative comment. Just an observation 😀 I've thrown out stuff that was in the wrong place at the wrong time.
1982 to 2001
Reply 31570 of 52813, by MKT_Gundam
This Ct3620 with memory chips at flea market for 5 bucks.
I dont have idea about the memory size.
Aopen AS9200 AKA Avance Logic ALS4000 from recycler center:
M-audio Audiophile 2496
No pics, Asus cu4xv with ISA slot.
Will be for my Via c3 800mhz build.
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 31571 of 52813, by liqmat
MKT_Gundam wrote:
This Ct3620 with memory chips at flea market for 5 bucks. https://imgbbb.com/images/2019/12/12/IMG_20191212_094134428.md.jpg […]
No broken memory clips at a flea market? Christmas miracles do actually happen!
Reply 31572 of 52813, by MKT_Gundam
A trully Christmas miracle! 🤣
The memory chip info
NEC JAPAN
D421000GS-60
9438V716
Reply 31573 of 52813, by wirerogue
i hope there is a build log coming.
Reply 31574 of 52813, by gex85
MKT_Gundam wrote:
M-audio Audiophile 2496 https://imgbbb.com/images/2019/12/12/IMG_20191212_094014276.md.jpg […]
I keep seeing those pop up at eBay Classifieds, sometimes as cheap as 10€. Always wondered if I should get one... what do you guys think about this card?
Edit: Nevermind, just saw that you already opened a separate thread: M-audio Audiophile 2496
Otherwise, nice finds! I never found any interesting retro hardware on local flea markets. People sell all sorts of random crap, but no computer parts at all.
My retro computers
Reply 31575 of 52813, by cj_reha
appiah4 wrote:
That Amiga 2000 is easily worth more than the rest of it all combined to me. Wonderful find. What are your plans with it once you repair the corrosion damage? Any upgrades in the pipeline?
I'm not sure, to be honest. I'd at least like to find a hard disk controller for it, but searching on eBay, I could not find one listed for less than what I paid for the machine itself with or without a drive included. 😲 Perhaps I could get a Buddha board, but it's only marginally cheaper..still pretty pricey. For now I'm pretty sure it'll stay stock at least until I can find something interesting to stick in it.
Reply 31576 of 52813, by cyclone3d
on eBay there is a SCSI controller for $43 + shipping.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 31577 of 52813, by my03
Hey guys
I won and got my actual NOS Genious serial mouse home today. Installed drivers for dos 5.0 & wfw3.11 and it works great on my Toshiba T5200. Awesome 😀
Reply 31578 of 52813, by PC Hoarder Patrol
It would be rude not to, right 🤣 😀
Not sure of the exact specs atm, but probably something like:
CPU - dual sloketed coppermines (I know the modded v2 MS6905 Masters work with 850/256/100s, but I'm less sure about the 1000/256/100s, as the one I have to hand seemed unstable in single processor mode)
RAM - 1GB of PC100/133, although I did see a post here that these boards mis-report that much, but mine seems happy to report the full amount even if I mix brands and speeds of 256MB simms.
Video - probably something ATI, a 9800 Pro or maybe an X800
Sound - Creative, thou not sure what
Storage - SCSI all the way, thou may add some ATA/IDE as well
PSU - have a few period correct Enlight / AcBel between 300-400W that should do
Case - space dictates this will not be a full tower build, but I have some nice Macase / Enlight midi-towers from the period.
OS - may try out a few including 2000 Pro, XP Pro, W7 and maybe even Warp
Liking your dual workstation build btw 😎
Reply 31579 of 52813, by MKT_Gundam
gex85 wrote:
I keep seeing those pop up at eBay Classifieds, sometimes as cheap as 10€. Always wondered if I should get one... what do you gu […]
I gonna use for "basic sound". Still better than that CMI soundcards at lest least
Dos and others things, my sb32
