Reply 32180 of 53165, by boxpressed
This oddity arrived today: a Simuleyes VR 3D Stereo Vision System. It was cheap, and the glasses looked new, and it comes with a CD-ROM with some pretty good games on it (see photo). I haven't had time to test it, but it should be amusing for a little while.
1.69 MiB
Reply 32183 of 53165, by PC Hoarder Patrol
Made this deal a week or so back, though only getting to the 1st round of pics today, but considering what I got I'm still pretty stoked!
Since joining the forum I've developed an interest in dual systems and am keen to try some builds in this area (have already got a P2B-DS that I've started plans for). So, I get an email from an occasional contact who knows my interest, telling me he's selling up a lot of his personal spare server board collection and would I be interested - hell yeah 😀
Sadly all the dual Slot 1 boards (my favourite) had gone but he offered me what was left of the dual socket 370 boards plus some processors and loads of PC133R, so here's what I bagged:
Gigabyte GA-6VTXDR-C, complete with 2 x PIII-S 1.4GHz
Asus CUR-DLS (OEM) from a Fujitsu Siemens Primergy B210, complete with 2 x PIII-933MHz Coppermines
Asus TR-DLS, complete with 2 x PIII-S 1.4GHz
IBM eServer xSeries 342 board (ServerWorks ServerSet III HE-SL), complete with 2 x PIII-S 1.4GHz, spare VRM modules and cabling
Only had a chance so far to check out the Gigabyte board so here's the pics (rest of the haul to follow soon)
Found this image online of the board launch at Computex 2001
216.47 KiB
and now a few of mine
967.38 KiB
486.4 KiB
1018.96 KiB
It's a early v1.0 board and although it should take the full 4GB it seems a bit flakey with that much but solid at 3.5GB. Also noted that they got the slikscreen for CPU1 & CPU2 mixed up, oops
Reply 32184 of 53165, by PC Hoarder Patrol
...and lastly the PC133R
1.27 MiB
and the coolers I've been using to test with
909.11 KiB
Reply 32185 of 53165, by gex85
PC Hoarder Patrol wrote on 2020-01-27, 23:01:
gex85 wrote on 2020-01-27, 21:22:
... it looks like the GA-6VTXDR-C to me, right?
That's exactly the board I have in my dual Tualatin box, used it as a home server some 12 years ago. It's a nice and stable board, but unfortunately lacks the AGP slot. I still don't have a good PCI graphics card to pair it with. But it is going to receive an upgrade from 2x 1.26 GHz to 2x 1.4 GHz soon. It's maxed out with 2 GB of SD-RAM, too 😄
What a shame that yours is damaged though!
I picked up a GA-6VTXDR-C recently (no pics yet) and I've maxed the RAM to 4GB of PC133R (though a little flakey) - you sure yours doesn't take more?
Well, it's been a while since I built the system, but I always thought that 2 GB is the maximum indeed.
That's what the Gigabyte website says as well:
GA-6VTXDR-C (rev. 1.0) Specs Overview
Dual Intel® Pentium III Tualatin processor (Socket 370 / 133MHz FSB / up to 1.4 GHz )
VIA® Apollo™ VT92C694T, VT82C686B
Max. 2GB Un-Buffered or Registered (ECC) PC-133 SDRAM Memory in 4 Angle DIMM Slots
Intel® 82559 10/100 Mps Fast Ethernet Port
Promise® PDC20267R Dual ATA-100 channels with IDE RAID 0,1, 0+1
ATX 12" W x 9.6" D Form factor, Standard ATX Power
Source: https://www.gigabyte.com/de/Server-Motherboar … XDR-C-rev-10#ov
Would be a nice surprise to see it supporting 4 GB, although I would have to go hunting for 1GB SD-RAM modules 😉
However, that's some really nice stuff you got there 😄
-- Edit:
Had a quick look at the manual, seems to be 4 GB indeed. Cool.
Memory
4 168-pin DIMM sockets
Support PC-100 / PC-133 SDRAM and VCM SDRAM
Support up to 4GB DRAM (Max)
Support only 3.3V SDRAM DIMM
Support 72bit ECC type DRAM integrity mode
Support registered or un-buffered DRAM
My retro computers
Reply 32187 of 53165, by Xicor
Last Sunday I manage to find a asus 9800GX2 at local flea market @ the incredible price of 7€ ..... At first I thought that it was broken in some way, so I wasn't expecting much.
537.34 KiB
697.29 KiB
As luck would have it, the card was without fault. It posted fine and working correctly. Now I have to replace all the pads and thermal compound. These beasts run hot as hell and 12 years is way too much for those puny pads.
Reply 32189 of 53165, by mpe
My $19 GUS ACE purchase I was so excited a few days back really arrived today. And I actually came to appreciaton the rest of the bundle as a cheap source of 256Kx16 DRAM upgrade chip for the GUS 😀
Blog|NexGen 586|S4
Reply 32190 of 53165, by bjwil1991
I need to or have someone design a multi function ISA card that'll have GUS ACE, Creative CMS (GameBlaster), Yamaha YM2151, Sigma Designs RealMagic (the audio out will be shared to have more room for the VGA in and out, along with the RJ45 ethernet ports), and 3Com 3C509 Ethernet. But, that probably won't work out too well, but, I'd say that'll be worth it.
Reply 32191 of 53165, by imi
mpe wrote on 2020-01-28, 20:13:
My $19 GUS ACE purchase I was so excited a few days back really arrived today. And I actually came to appreciaton the rest of t […]
that poor diamond stealth though ;u; that is a really pretty PCI card.
I'm sure there are plenty of other cards you could source ram from.
Reply 32192 of 53165, by HanJammer
imi wrote on 2020-01-29, 00:43:
^^^ This.
Fortunatelly the chip is socketed and can be put back into it's place when he finds some other donor...
Reply 32193 of 53165, by LeFlash
Robert B wrote on 2020-01-26, 07:28:
Your observation is pertinent though. 😁 UV EPROM + BRIGHT SUNLIGHT = LOVE (NOT!)
It takes weeks of bright sunlight to erase an EPROM.
Trust me - i tested it as a kid! 😉
The UV-B-part has appromixately 11W/m², that's roughly the same that a UV-lamp will put out on a much smaller area.
It's simply not enough - especially if it just sits for some minutes or hours in the bright sun.
For extra safety you can read the BIOS from DOS (f.e. with DEBUG) and save it somewhere.
Reply 32194 of 53165, by PC Hoarder Patrol
Rest of the dual boards from my recent deal
IBM e server xSeries 342
662.32 KiB
819.64 KiB
908.88 KiB
Asus TR-DLS
899.41 KiB
597.92 KiB
Reply 32195 of 53165, by PC Hoarder Patrol
and finally
Asus CUR-DLS (Fujitsu Siemens OEM)
922.21 KiB
564.98 KiB
878.2 KiB
I even managed to get the Gigabyte board working with the full 4GB of RAM, although I'm not quite sure why. All the memory I got with the boards have 333 timings except for one set with 222, and this is the only one that allows me to max the board.
Reply 32196 of 53165, by RacoonRider
PC Hoarder Patrol wrote on 2020-01-29, 07:45:
reserved
Just and FYI - when you reserve a post and someone sees it before you edit it, it counts as "read" and does not show up when you view latest unread posts in the thread. That and it's also frustrating to check out a thread that is marked as having unread posts only to find out a reserved space.
Reply 32198 of 53165, by canthearu
HanJammer wrote on 2020-01-29, 07:29:
^^^ This.
Yep, the diamond multimedia cards are generally well built versions of the S3 cards. A lot of the other S3 cards can have particularly nasty output.
Reply 32199 of 53165, by mpe
^^^ This.
Indeed. However, there is another good reason. The soldered-in DRAM chips on the Diamond Stealth 64 are 60ns EDO capable KM416C254BJ chips. While perfect for the GUS the ones in sockets (Toshiba TCS514260BJ) are just slower 70ns FPM parts. Not sure if it was like that from the factory or a result of some ill-informed homemade upgrade. I eventually plan to put 60ns EDO RAMs for the Diamond Stealth and restore it to former glory.
Blog|NexGen 586|S4
